Skybox F5s Recording
Yes, same here. Like I said, I've always assumed from reading previous posts that a stick should be formatted to FAT32 and have never tried NTFS myself. I checked the Skybox website for more info but as I'm sure you already know the support there is pretty limited and there's no info regarding which usb formats it supports.I've never tried an NTFS formatted memory stick. All mine are FAT32.Comment
And a short tutorial taken from a previous post of mine:
An upgrade is done at your own risk and you may lose important, irrecoverable files so:
As always, first back up your original files before performing a software update. Using a USB stick that has been formatted to FAT32, enter the " Dump By USB " menu of your Skybox and first select the Image file ( which is your software backup ) and dump to the usb. Then change the image setting to miscellaneous files and select TP_PROG.dbs ( your channel list ) and CCcam.cfg ( your gift provider ) and dump these also. Make sure that you place a tick in each file you are dumping to usb by either selecting OK or the yellow button on your remote. Copy these files to a safe place on your PC. To upgrade, download the new software and extract it using the appropriate programme e.g. Winrar etc., then copy it to your usb stick. Once inserted, navigate to the " Upgrade By USB " menu option, select the image file, making sure it is ticked by pressing the OK or yellow button on your remote, do not alter any other settings and select upgrade. Wait for the upgrade process to finish and the box should reboot. If it does not reboot do it manually by powering off then on using the remote.Comment
Will I loose all my channels if I upgrade?http://www.digital-kaos.co.uk/forums...-fixed-412950/
An upgrade is done at your own risk and you may lose important, irrecoverable files so:Comment
As long as you don't alter the default setting of "Yes" for " Keep DBS Settings " when you upgrade the software then you shouldn't lose your channel list or any other files but it's always a good idea to back up your files just in case it does happen. Even if you was to lose your channels it's no big deal to update them again and I expect that if you've never updated them before then they need to be updated anyway.Comment
Sattv5's channel list contains the EPG channel data for ITV/ITV HD however, it's not up to date as AJ's is. You could use Mediabox Editor Studio to copy the ITV channel from sattv5's list to AJ's list to get the best of both worlds or wait for sattv5 to update his channel list , hopefully soon.
Mediabox Editor Studio is available from this forum's download page.Comment
Cheers for the help lads.Sattv5's channel list contains the EPG channel data for ITV/ITV HD however, it's not up to date as AJ's is. You could use Mediabox Editor Studio to copy the ITV channel from sattv5's list to AJ's list to get the best of both worlds or wait for sattv5 to update his channel list , hopefully soon.
can I use the editor studio to copy the movies epg as well?Comment
