OK so here is the issue I am having, when I got my V5S I upgraded it to the latest Skybox firmware from Skybox.cc, upgrade went fine. Problems I am facing is Youtube does not work 90% of the time, so I thought I'll reflash the firmware. I have tried Openbox V5S firmware and Skybox firmware both give the same issue. UPGRADE FILE MISMATCH.
Doing a bit of research it seems this is a problem with clone boxes. Problem is mine is not a clone or it would not of let me upgrade it originally when I got it.
My box info is
MAIN CHIP: ALI HD 3601 . 3501C
OEM ID 0001
Software 3601HD_10_04_2014_0670
Perhaps you can only flash firmware newer than what is currently installed? I only wanted to reflash.
My box info is
OEM ID 0001
