Skybox Picon File (FULL)
  • tech1200
    • May 2014
    • 6
    Don't know if this has been done before, but I was getting fed up with lots of missing icons on the EPG, so I have updated the .ics file and inserted a logo for every channel.
    Cheers
    0282E.zip
  • danpearson
    • May 2011
    Please can you talk me through putting it onto box. Thank you.
    • martin035
      • Apr 2014
      • 1308
      1. Unzip the file, provided by tech1200 above, you should now have a file called 0282E.ics
      2. Place the 0282E.ics file on a USB drive and leave plugged into the back of your F3S/F5S
      3. On your remote press 'Menu' then navigate to 'multimedia' the select 'Picon View'
      4. Change 'Picon View' to 'On'
      5. Restart your F3S/F5S
      • bigade1
        • Oct 2013
        • 340
        Also bear in mind when following martin035's instructions that the Picon View menu options and functions are only available in the late December 2013 software and later. Therefore you may need to update your software if your box was supplied with an earlier software version
        • openup
          • Sep 2012
          • 51
          picons don't match up with channels. i get HD picon on +1's and atlantic as living although +1 atlantic is atlantic hd.
          • martin035
            • Apr 2014
            • 1308
            Here try mine, but please remember, like a channel list the picon list also needs to be updated/maintained, this can be done via the Skybox_picon_tool available from skybox.cc
            • openup
              • Sep 2012
              • 51
              Thanks will try now.
              Not sure about maintaining but skybox.cc has decided to take down some download files. Libertview.com has the picon tool
              • woka
                • Aug 2013
                • 8
                hi just a few picons missing if they could be added and I'm using the latest AJ's channel list 16/8/14 other than that quality picons so far well done!
                sky living +1
                sky atlantic
                watch
                alibi
                comedy ctrl +1
                comedy ctrl x & +1
                sky livingit
                tlc
                tlc +2
                lifetime +1
                challenge +1
                sony tv +1
                dmax +1
                cvs reality +1
                truTV
                E!
                Pick & +1
                quest +1
                showcase
                showcase 2 +1
                into +1
                sky sports 5
                setanta ireland
                setanta sports 1
                premier sports
                box nation
                box nation hd
                cheers
                • martin035
                  • Apr 2014
                  • 1308
                  woka, I don't use AJ's channel list anymore and a lot of those channel you've list I've deleted, are on a different frequency or I just haven't changed the original picon, hence why the picons don't match up or they default to the none +1 picon. But if you upload your 'channel_info.xml' file I'll see what I can do.
                  on the remote, Menu-Tools-Dump by USB.
                  Dump mode - Misc files
                  Select and dump
                  Green then yellow
                  • woka
                    • Aug 2013
                    • 8
                    here is my channel info
                    • martin035
                      • Apr 2014
                      • 1308
                      woka, I've aligned the picons with your Channel_info.xml (AJ's channel list 16/8/2014) couldn't find any reference to into+1 or cvs reality, just remember as AJ delivers new lists/Frequencies change you will loose alignment of the picons. You then need to use the Skybox picon tool to realign.
                      • woka
                        • Aug 2013
                        • 8
                        Thx martin035
                        i would like to use the skybox picon tool but i can't find the download on skybox.cc, but it might be difficult as i have a Apple macbook Pro not a windows operating system so the tool might not work on my mac
                        • martin035
                          • Apr 2014
                          • 1308
                          Originally posted by woka
                          Thx martin035
                          As openup posted above it's also available from Libertview.com
                          It's only a basic program so I'm sure a program like Parallels or Winebottler would allow it to work on a mac.
