Don't know if this has been done before, but I was getting fed up with lots of missing icons on the EPG, so I have updated the .ics file and inserted a logo for every channel.
Please can you talk me through putting it onto box. Thank you.
1. Unzip the file, provided by tech1200 above, you should now have a file called 0282E.ics
2. Place the 0282E.ics file on a USB drive and leave plugged into the back of your F3S/F5S
3. On your remote press 'Menu' then navigate to 'multimedia' the select 'Picon View'
4. Change 'Picon View' to 'On'
5. Restart your F3S/F5S
Also bear in mind when following martin035's instructions that the Picon View menu options and functions are only available in the late December 2013 software and later. Therefore you may need to update your software if your box was supplied with an earlier software version
Here try mine, but please remember, like a channel list the picon list also needs to be updated/maintained, this can be done via the Skybox_picon_tool available from skybox.cc
hi just a few picons missing if they could be added and I'm using the latest AJ's channel list 16/8/14 other than that quality picons so far well done!
sky living +1
sky atlantic
watch
alibi
comedy ctrl +1
comedy ctrl x & +1
sky livingit
tlc
tlc +2
lifetime +1
challenge +1
sony tv +1
dmax +1
cvs reality +1
truTV
E!
Pick & +1
quest +1
showcase
showcase 2 +1
into +1
sky sports 5
setanta ireland
setanta sports 1
premier sports
box nation
box nation hd
cheers
Reason: new list
woka, I don't use AJ's channel list anymore and a lot of those channel you've list I've deleted, are on a different frequency or I just haven't changed the original picon, hence why the picons don't match up or they default to the none +1 picon. But if you upload your 'channel_info.xml' file I'll see what I can do.
on the remote, Menu-Tools-Dump by USB.
Dump mode - Misc files
Select and dump
Green then yellow
woka, I've aligned the picons with your Channel_info.xml (AJ's channel list 16/8/2014) couldn't find any reference to into+1 or cvs reality, just remember as AJ delivers new lists/Frequencies change you will loose alignment of the picons. You then need to use the Skybox picon tool to realign.
i would like to use the skybox picon tool but i can't find the download on skybox.cc, but it might be difficult as i have a Apple macbook Pro not a windows operating system so the tool might not work on my mac
