Transponder frequency's Measat 3/3a
  • basjke
    • Sep 2014
    Hi guys, I am located in Thailand and use a Skybox F3 connected to a KU disk with universal lnb pointed at the Measat 3/3a at 91.5E.
    Now when I do a satellite scan, I enter all the transpnders manually and do a preset scan, I can find signal on all the frequency's in the 11000 mnhz band. That is where the Astro sd channels are located.
    However when I do a scan for the 12000 Mhz channels, where the HD channels are located, it finds no signals.
    My lnb setting is Universal 9750-10600 on automatic.
    I have already tried other lnb settings and entering only the 12000 Mhz tp's. but to no avail.
    This are the transponder settings I use.
    Astro on Measat 3/3a at 91.5?E - LyngSat
    So what am I doing wrong that it doesn't find a signal on those transponders ?
  • basjke
    • Sep 2014
    In my storage I found another paper weight satellite receiver, Hitech HT-89HD, and connected that one instead of the skybox.
    Apart from the usual universal LNB settings, 9750-10600 9750-10700 etc., it has also a setting that simply says Universal.
    With the latter setting a scan will read all the HD channels on the +12000 Mhz frequencies.
    So the only problem is that the Skybox F3 doesn't has the "Universal" setting.
    Any way around it with maybe custom firmware ?
