Hi guys, I am located in Thailand and use a Skybox F3 connected to a KU disk with universal lnb pointed at the Measat 3/3a at 91.5E.
Now when I do a satellite scan, I enter all the transpnders manually and do a preset scan, I can find signal on all the frequency's in the 11000 mnhz band. That is where the Astro sd channels are located.
However when I do a scan for the 12000 Mhz channels, where the HD channels are located, it finds no signals.
My lnb setting is Universal 9750-10600 on automatic.
I have already tried other lnb settings and entering only the 12000 Mhz tp's. but to no avail.
This are the transponder settings I use.
Astro on Measat 3/3a at 91.5?E - LyngSat
So what am I doing wrong that it doesn't find a signal on those transponders ?
