Just in case you're unaware - Boxnation HD is only a " part -time " broadcasting channel i.e. it only broadcasts mainly live events at the weekends. Even with the correctly tuned frequency in the weekdays you will have an " invalid channel " or similar message appearing on screen.
I jnow that mate but its not even there to see its like its not picking up when entering the frequency
bt sports etc come up...
That's because it isn't there!
The transmissions are switched off completely until there's a live fight to show. So doing a scan at a time when it's not actually broadcasting won't pick it up.
If you scan between 1.45am and 7am on Sunday morning then it will pick it up.
You will still pick up other channels that broadcast on the same transponder though.
Hi guys
I remember having to put in a different channel number to get the re runs last time will this be possible as i understand BN HD run them most of the following day after the main event
Boxnation HD has now gone off air until next Saturday evening so you won't see any re-runs on that channel. The SD version can be found on the following frequency 12552 V and it looks as if it's showing a re-run at the current time of my post.
Cheers dude yes can get the SD re run just last big fight they did the re runs on HD but no biggy!!
No probs. I actually watched it live on the HD channel and immediately after the programme finished a screen was displayed stating to switch to the SD channel for further programmes and that the HD channel would return next Saturday evening. You'd think that they would leave that message displaying continously but now I just get the " Invalid Search " message when I switch the HD channel on.
