Skybox f3 to Italian FTA channels
This topic is closed.
  • walf
    • Mar 2013
    • 112
    If I aimed a dish at 13e hotbird would it be possible tune a skyboxf3 into italian free to air channels? Is there something I would need to do in the menu or would just a blind scan do the job? The box is preloaded with the uk aj's list etc...
  • P&D
    • 2686
    Yes defo possible to get the channels
    set the dish to 13E & as you say do a blind scan
    i'm sure Aj's list has all the sat's included (it did when i used it a few years ago)
    • walf
      • Mar 2013
      • 112
      So there would be nothing I would need to do in the menu other than plug the box into the sat feed and do a blind scan?
      • P&D
        • 2686
        correct mate as long as the dish is pointing in the right direction I.e 13E
        • walf
          • Mar 2013
          • 112
          At the moment my box when I go to menu,antenna setup,sateillite says (1/1 sky uk 28a). My dish is currently aligned to astra. I want to take the box to a friends house who has a dish pointing at 13E. Would this just automatically change? He is Italian and looking for a box to get Italian FTA. You think this is possible?
          • Hadron
            • 2102
            Go to menu > installation > satellite list. Scroll down to Hotbird 6/8/9 at E13.0. Press OK to select it with a green tick & press exit to save.
            It can now be selected in Antenna setup & single satellite search.
            • walf
              • Mar 2013
              • 112
              Will that be me good to go with a blind scan after that? What I am doing here is finding out what his dish is capable of picking up with an old f3 I have before I telli him to go buy a box for himself. I will then return my box to my settings when I bring it home.
              • Nutsandbolts
                • Oct 2011
                • 1168
                Hi if your friend has a fixed dish then i would do the following:
                1) Delete all TP's(frequencies) for Hotbird. This will get rid of good and bad frequencies.
                2)Do a blind scan - this will retune all up to date frequencies/channels etc. This is assuming the dish is properly aligned to Hotbird. You can tell if its aligned properly by the numbers of channels found. If its an HD receiver it should tune in over 1000 channels.
                3) When scan completed you can edit the channels in the order that you want etc.
                Regards.
                3) edit channels in the order that you want.
                • walf
                  • Mar 2013
                  • 112
                  I'm assuming his dish is ok. The problem he has is Rai 1,2,3 are now encripted to FTA Italy. He basically has two options that I can see if he wants these channels back.
                  1. Tivusat box and card paired from ebay is around ?150 and will get him all FTA plus Rai 1,2,3. Im sure he could get it from Italy cheaper but not sure?
                  2. He tries out a skybox f3 if all the channels tune in but pays are scrambled then he could sub to a server?
                  • P&D
                    • 2686
                    Sorry buddy but with that question you have over stepped the form rules.......answer to your last question ......is Google
                    • satsmo
                      • 6397
                      Closed, we have a report button please use it.
