Skybox f5s some channels have no signal
  • mmaws1985
    • Mar 2014
    Hi guys some of my channel mostly music ones just say no signal.95 percent of my channels work just fine.Clubland tv,Heart tv,MTI,Planet pop etc are all saying no signal.Im using the latest up to date aj list.Can anyone help or tel me whats wrong.Thanks mark.
  • antomac
    • Oct 2013
    • 315
    have you another sky box coming off your satellite dish if yes
    you may need the no signal fix that you can buy off e bay fof
    ?5
    • antomac
      • Oct 2013
      • 315
      No Signal Fix for OpenBox S9 S10 S11 S12 - SkyBox F3 F3s F4 F4s F5 F5s
      • Dean121013
        • Oct 2014
        • 4
        I had the same problem but a lot more channels missing and it was my sky dish that wasn't alined properly
        • DLINKLA
          • 128
          I have recently had this problem.
          All worked originally now says no signal on most channels
          I've tried switching to dish with no other box on it and still the same
          Any ideas of what I can do
          • DLINKLA
            • 128
            I've tried this box at a different location and still days no signal on most channels
            Only a few work.
            Could this be a software problem ? How so I check I've got the right latest software
            Any other ideas of what the problem is
            • antomac
              • Oct 2013
              • 315
              Only a few work.
              did you try no signal fix as other than dish not being aligned properly
              this is more than likely your soloution it occurs a lot where some
              universal lnb use 13v for vertical channels and 18v for horizontal channels
              andsome receivers operate at a higher voltage which makes receiver not
              being able to switch via horizontal and vertical which results in you getting
              no signal on some channels
              • elrasho
                • Jan 2013
                • 46
                Anyone have a guide on how to install that part from Ebay?
                • antomac
                  • Oct 2013
                  • 315
                  its simple to do just put one put your cable from your dish on one side
                  and put the other side into box where your cable was
                  • elrasho
                    • Jan 2013
                    • 46
                    Thanks easy enough
                    • DLINKLA
                      • 128
                      I consider this strange but
                      V channels are working but H channels are not
                      Any ideas of what is wrong ?
                      • antomac
                        • Oct 2013
                        • 315
                        I give up honestly
                        • DLINKLA
                          • 128
                          Very helpful thanks
                          • jay876
                            • May 2014
                            • 14
                            I got the same problem with my old skybox f5s box with V channels working the H not. I did try everything with no luck so I ended up buying a new box. I have been told that it may been the tuner that is faulty.
                            • charlie567
                              • Mar 2013
                              • 50
                              which box did you buy instead jay to get round this....just for information thats all
                              cheers
