Skybox f5s some channels have no signal
  • DLINKLA
    • 128
    #16
    Could this be a tuner issue meaning a new box is needed
    • sexysam
      • Oct 2008
      • 209
      #17
      I thinks its the LNB /Dish problem rather than a tuner problem,,,try it in a friends house to see if problem is there
      • sexysam
        • Oct 2008
        • 209
        #18
        • Hadron
          • 2102
          #19
          DLINKA has already tried it at a different location.
          If you know someone with a digital multimeter, you could try unscrewing the LNB lead & poking a pin or bare wire into the LNB socket & measuring the voltage when tuned to a vertical & horizontally polarised channel.
          You should see around 13 - 14v on vertical & 18 -19v on horizontal.
          If you don't then it looks like a component may have failed in the box.
