skybox v8 setup.help needed
  • kevwal1969
    • Oct 2014
    Have bought 2 skybox v8 to use as multiroom.
    I have set up the box but am getting no satellites. Tried.different frequencies but keeps saying no programs. When scanned. Tried swapping satellite cable around and have even.Watched YouTube etc.
    In Newcastle area
    Any body have some.setup help please
    Regards kevin
  • paul93
    • 50
    You just have to put channel list and your gift and thats it because firmware is already installed
    • supercelt
      • Apr 2014
      Channel List Upload
      How do you add a channel list there is no load DB function and you cant seem to add bouquets either I have latest firmware installed,
      Channels are a mess lucky there is a A-Z channel bouquet,
      Hope you can help,,
      • Hadron
        • Nov 2012
        • 2102
        Hope you can help,,
        I don't have a V8 myself, but I thought it was done the same way as all the other openboxes/skyboxes.
        Menu > tools > upgrade by USB > upgrade mode = misc files > select & upgrade = TP_PROG.dbs.
        • gary229
          • 265
          Get your latest list from Aj sats, then follow Hadron's instructions
          • gaz02lyn26
            • Jan 2014
            • 21
            just to confirm as i have a v8s the channels are added the same way as the f5s/v5s ,follow hadrons instructions
            • gary229
              • 265
              Yep that's the correct way to do it, then your fta channels will be watchable
