my F3S box is hard wired to my router, at the box both yellow and green lights flash, at the router only the yellow light flashes, is that normal or signify a communication issue?
Ethernet connection
Sounds like your internet (router) isn't working properly. This would be the case if you had issues with your viewing certain channels. Generally I would reboot router and reboot box fingers crossed then everything is working normally after that. Sorry for the vague answer, maybe taking a photo of your router as it is just now with the lights etc may be easier to say if there is a problem as all routers are different. My previous routers would show numerous green flashing lights. I am currently with vermin so my lights are blue but more than one should be lit. Hope that makes sense? -
Box is goosed
Tried another box which worked fine so looks like it's the Ethernet socket is at fault. I'll bin it and get anotherComment
