Please help
  • Noycee
    • Feb 2014
    • 24
    Please help
    I had an f5s worked great for a year then I got no signal on any channel,i brought a new 1 on fleabay and it worked for a month now it also says no signal on all channels,what could be causing this?i brought the no fix thing that didn't help please can some1 enlighten me.cheers
  • benny/9
    • 1964
    if your only using the box on one satellite
    have you tried factory resetting the box then
    set it up again and scan the satellite to see if that
    clears the problem, then if it does move the channels in
    your personnel order.
    Please Read Carefully!
    • Noycee
      • Feb 2014
      • 24
      thanks for the reply benny I only have 5% signal now were as before I use to have 80?
      • mickzer
        • Nov 2013
        • 81
        Sounds like your dish may have moved.
