Hi i put this up in the recover dead box section few days ago but no one replied, so im hoping someone can help.I have a freinds v8s box it was stuck on load after doing up date so i have tried to flash it quite a few times. Anyway 1 did work but all its done is take the load off the front. And now im getting nothing at all, no lights anything. There is power because if i put internet to it, it flashes at back yellow and green. Any ideas as im stuck ? thanks in advance.
V8S Help
Tags: None
Sounds like the wrong firmware has been flashed
Is the box a clone ??
These should help
or
So if it is a clone is there a differnt firmware i should be loading on it? If so where from? thanks josh.Comment
If it still doesn't work after trying a few different firmwares, you could try a different power supply.
Although the lights on the ethernet port are working, sometimes the voltage from a failing PSU goes noisy before failing completely.
If you have another power supply with the same voltage (12v), same polarity (+ve to centre pin), & current rating (2A or more), then you could try that.Comment
