Problem with my skybox f5s
  • trepca123
    • Sep 2014
    • 13
    i have skybox f5s and my problem is, skysport 1,2 is fine but 3,4,5 skysport news scrambeld
    same with mtv music some yes some scrabeld ,same with kids cartone
    i m sure***** is fine becouse i have same box on other room and i m using same *****, and same channe list from ajsat
    but if i go to if i go to provider ore alfabetic serch skys sports 3,4,5 and all fine my not in my favorite list,i delite list and put new ajsat file still same
    anyone know how to factoty reset? what to do thanks.
  • patch1gizmo2
    • Sep 2014
    • 5
    I have same problem tried everything to get them back done software tried a few channel updates to no avail any help would be appreciated
    • P&D
      • 2686
      Turn the box that works ok OFF at the wall
      Then see if the box missing the channels goes ok .....I.e missing channels come back
      • trepca123
        • Sep 2014
        • 13
        i try but still same ,and if i go to search for channels by alphabet on transponder is fine but not on favorite list
        • gary229
          • 265
          Sounds to me like a signal issue. are you using a splitter? Check all your connections, spoke with someone the other day with the exact same issues, turned out to be a signal issue
          Hope this helps
          • trepca123
            • Sep 2014
            • 13
            i m using no splitter, i dont understand why for example skysport 1.2 is fine not 3.4.5,same with mtv hits yes not mtv clasic base , all this channels i get if i go to trasponder by alfabes serch, but not on favorite list ,
            • trepca123
              • Sep 2014
              • 13
              please anyone can help me?? thanks
              • P&D
                • 2686
                You need to delete the channel list off the box..........so when the box starts it has NoCH on the front of the box.
                Then install Aj's latest list ........http://www.digital-kaos.co.uk/forums...=1#post2633407
                Once this is done we can discount this.......& move on
                • gary229
                  • 265
                  install Cwaites channel list, had same issue with one of my friends and its done the trick
                  • trepca123
                    • Sep 2014
                    • 13
                    no mine still not okey, you cant fix this never,i have this problem now in my friend box too,only option is to go outside favorite list and find in transponder ,now i m sure 100% no one can fix and i need new box ,never ever skybox
                    • r1dave
                      • Nov 2011
                      • 35
                      I have a f5s that has the same problem. I have reflashed this box with a number of firmwares all successfully
                      still the same problem exists. the box is the only one connected to lnb and ive tried another f5s with the same
                      info and it works.
                      when you do a blind search certain transponders fail and these are the ones with the missing channels.
                      whilst messing with box I found the power supply is critical when reflashing..ie it must be 2amp either 5v or 12v work.
                      and this is where im at with it. any suggestions peeps
                      • martin035
                        • Apr 2014
                        • 1308
                        info and it works.
                        So you have one f5s that on a blind scan finds all the channels and works ok, but you have another f5s that with the same firmware, used on the same satellite feed on a blind satellite scan doesn't find all the channels, sounds like to me that box is knackered, might be time to upgrade and get a better box.
                        • r1dave
                          • Nov 2011
                          • 35
                          it displays scrambled on certain channels but it appears to be on certain transponders
                          • P&D
                            • 2686
                            Easy to find out if its the box......Simples
                            Download a backup of the good box onto a USB (full backup)
                            Then load this onto the box you having the problem with
                            See if that sorts the problem if its still the same then its what Martin said ~~~~ed box
                            • DW190
                              • May 2012
                              • 1263
                              Try the box on a fixed ip and change the DNS to googles. Preferred 008.008.008.008. Alternate 008.008.004.004
