Having issues with new virgin super hub connection
  • icass
    • Feb 2016
    • 4
    Got new openbox v8 Pro and can't seem to get it to work with my VM broadband connection, I know the box is okay because I have been tethering with mobile all day watching the football. When I try & use my VM with either the ethernet cable or use the wifi dongle it works for a minute or so then shuts off and I loose the connection with the channel. Tried disabling firewall on hub and still no luck, don't know what to do now if anyone has any ideas.
  • digicon
    • 8261
    Read somewhere the parental controls or something similar need disbling
      Make sure your firewall is set to low in your superhub
      • DW190
        • May 2012
        • 1263
        Go into Network Settings on your box and turn the DHCP Off.
        Now enter a fixed IP something like 192.168.0.150
        Subnet 255.255.255.000
        DNS Preferred 008.008.008.008
        DNS Alternate 008.008.004.004
        Click Apply and reboot box.
        • icass
          • Feb 2016
          • 4
          Already turned of parental controls and Firewall.
          @DW190 Are you talking ablout the changing Virgin Hub settings or on my openbox because I couldn't where its possible to change DHCP on the super hub. Cheers
          • DW190
            • May 2012
            • 1263
            Settings need changing on your V8.
            Some Open boxes just wont connect through Virgins Domain Name Server.
            To direct it to a different DNS you have to use a static IP on your box (V8) then you can enter your own settings.
            The DNS I use is Googles as shown in the pic.
            • icass
              • Feb 2016
              • 4
              That hasn't seem to work, I do keep getting message "network cable in & network cable out" then goes back to this Encrypted Program.
              • DW190
                • May 2012
                • 1263
                That message suggests a connection issue with your Ethernet cable.
                Can you see the ip in your connected devices on your Hub?
                • DW190
                  • May 2012
                  • 1263
                  Work for a minute then shuts off? Does the picture actually freeze on the screen? if it does, try the box without the sat cable in. If you can then get into the menus without it freezing then there is another known issue with one of the files that is in folder that is out of the bounds of discussion on the forum.
                  Try googling issues with V8 and (******)
                  • DW190
                    • May 2012
                    • 1263
                    Reading your original post again. It worked OK tethering from your phone That would suggest its the first problem I mentioned with Virgins DNS.
                    • icass
                      • Feb 2016
                      • 4
                      Just sent PM
                      • Shanew9422
                        • Jul 2016
                        • 5
                        Have the same problem did you find a solution?
                        • paul93
                          • 50
                          Reboot your virgin hub and the v8 box at the same time and you will see the result.
                          • Shanew9422
                            • Jul 2016
                            • 5
                            Still the same. The virgin hub goes red and shuts off when the box is on for less than 1 minute
                            • portvalefanjosh
                              • Dec 2013
                              • 101
                              [QUOTE=Shanew9422;2801387]Still the same. The virgin hub goes red and shuts off when the box is on for less than 1 minute[/QUOTE
                              Im with virgin and super hub wired connection downstairs and wirless connection up stairs on both v8s boxes, and never had any problems at all. Sounds to me like it your hub is knackered, is it the super hub 3 by any chance?
