Zgemma vs F5s
  • hkphooey
    • Apr 2010
    • 232
    Zgemma vs F5s
    Hi guys
    Been looking at the Zgemma what would i gain from going from a F5S , i cant use the twin tuner as i only have a single sky feed at moment
  • martin035
    • Apr 2014
    • 1308
    An EPG that works , channel lists that update frequency changes automatically, a better user experience ie the menus/interface look much better and as has been pointed out to me on newer H series Zgemma's IPTV works pretty well.
    • trav6369
      • Nov 2013
      I have to agree with Martin. I finally took the plunge and replaced my f5's with a zgemma h2s....MASSIVE difference.
      • hkphooey
        • Apr 2010
        • 232
        Cheers guys, what would be the latest single tuner version please?
        • martin035
          • Apr 2014
          • 1308
          The Zgemma H.s can be sourced of the bay for around ?60, if you already have a f5s then that special magical file can be transferred over, saving you having to get another.
          • hkphooey
            • Apr 2010
            • 232
            Ahhh thats cool , cheers bud...Anyone can recommend a reliable seller on the bay of fleas please?
            • dunno87
              • Apr 2016
              • 84
              Chetsp on here sells them on eBay under username bankrupt_acc, the zgemma hs he does comes with all 3 openvix skins, kodi, the script etc....
              Plug And play basically, I'll be getting one next payday.
              • martin035
                • Apr 2014
                • 1308
                Aye, his prices for a H.s are very competitive especially seeing that it comes plug & play, but he's a bit over priced for the H2s but I suppose that extra money will save the hassle of doing it yourself for free.
                • kevinjm
                  • 13
                  had a skybox f3s just got zgemma hs did not like vix as they say its not supported put wooshbuild opeen atv on easy to set up and works a dream recording function is spot on
                  • martin035
                    • Apr 2014
                    • 1308
                    Aye, your right about vix, best to use openatv on all Zgemma's, this openatv backup image has a skyQ, original sky and VM skin and also works a dream
                    This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
                    • hkphooey
                      • Apr 2010
                      • 232
                      http://www.digital-kaos.co.uk/forums...3-Backup-Image
                      Cheers guys, got a twin tuner this morning, and can see from the description see is has Blue HD OpenATV skin preloaded!!! result...So i take it this is the closest box to a sly i will get for user experience??
                      • martin035
                        • Apr 2014
                        • 1308
                        No, an image loaded with kiddac's slyk skin v5 is the closest either mine or whoosh's will do, but blue HD is quite similar in style.
                        • hkphooey
                          • Apr 2010
                          • 232
                          Cheers bud...How about the series link etc is that workable?
                          • hkphooey
                            • Apr 2010
                            • 232
                            MAte can you help me please via PM??
                            • martin035
                              • Apr 2014
                              • 1308
                              Not as perfect at a legit sky box but it works, just go into the EPG and press the record button, 2nd option is the series link, you just need to set it up manually.
