Zgemma vs F5s
  • hkphooey
    • Apr 2010
    • 232
    #16
    Cheers for your help bud....was the ******* wrong in setting not finding the ****** file. What i would want to do now is set my local region in the ITV channels etc as default is London
    • Johnner
      • 7069
      #17
      C'mon Phooey...you know the routine here...
      • hkphooey
        • Apr 2010
        • 232
        #18
        Apologies sorry...
        • hkphooey
          • Apr 2010
          • 232
          #19
          I just cant for the life of me get the box to flash on boot!!! i have tried about 8 usb flash drive low level format's etc, i'm trying to get woosh on it as its seems the only way to go
          • martin035
            • Apr 2014
            • 1308
            #20
            As you think woosh's image is the way to go my advice is go and ask him to sort it out, as it could be the image that's causing the issue.
            • vorlon2257
              • Sep 2011
              • 356
              #21
              Have you tried holding the power button on the front as you turn it on, should go boot/usb then let go of power button then it should say flash.
              • hkphooey
                • Apr 2010
                • 232
                #22
                Sorry mate don't mean to offend its just that what's on the box at the moment is just not making much sense from what i have read and watched via videos etc. I just can't find related info to whats in the menu's etc.
                • martin035
                  • Apr 2014
                  • 1308
                  #23
                  You have got the right backup image for the H2s??? A lot of newbies get mixed up and download the wrong image ie get the older zgemma series instead of the newer H series backup image, easy to check, if once downloaded & unzipped in the Zgemma folder there is a 'sh1' folder you have the older Zgemma series backup, if there's a 'h3' folder you have a new H series backup image.
                  You need a 'h3' folder for your new backup image to flash on your H2s box.
                  • hkphooey
                    • Apr 2010
                    • 232
                    #24
                    Exactly the issue mate...sorted it now ive tried it i prefer yours ...only issue i had was the getting that all important info onto it but now i have fiddled about a bit think it could be easier, so will reflash back to your version looks lots better then the woosh IMO
                    • martin035
                      • Apr 2014
                      • 1308
                      #25
                      Phooey, I've just updated my image, added new picons and cleaned up the skins a bit, would advice you redownload the new image.
                      • hkphooey
                        • Apr 2010
                        • 232
                        #26
                        Perfect will do that now....i take it the link is the same ?
                        Thanks again
                        • martin035
                          • Apr 2014
                          • 1308
                          #27
                          Thanks again
                          No, Just uploading the image now, give me 5 minutes and you'll see the link on the post #1 of this thread;
                          This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
                          Edit: image link on post#1 of the above thread available for download
                          • hkphooey
                            • Apr 2010
                            • 232
                            #28
                            Got it on mate awesome...Only thing i can't seem to sort is the pause timeshift and recordings, mainly time shift and pause keep getting cross on screen top right when i hit pause or rewind, so many timeshift setting in menu i have no idea what i am changing
                            Many thanks
                            • martin035
                              • Apr 2014
                              • 1308
                              #29
                              Phooney, you need to delete some PM's so that I can answer your question about Zgemma resolutions and EPG updates
                              I don't use timeshift, so haven't set it up in the settings, you'll have to play with the settings, good luck
                              • hkphooey
                                • Apr 2010
                                • 232
                                #30
                                Oops now done that . Cracking upload love it thanks a lot.
