E P G (PROGRAM GUIDE)
  • misterminibus
    • Oct 2010
    • 9
    #16
    Originally posted by P&D
    You can't with the F3
    thats why I cant get it to work, thanks
    A wise old owl lived in an oak.
    The more he saw the less he spoke.
    The less he spoke the more he heard.
    Why can't we all be like that wise old bird?
    • portvalefanjosh
      • Dec 2013
      • 101
      #17
      Anyone fancy help me the xmltv epg goes on 1903 every time I switch the box off and it's the same on the upstairs box too. I have too update it every day over 5 times too get the normal date back. Any suggestions? It's a v8s box thanks Josh.
      • PutTheFootieOn
        • Feb 2014
        • 75
        #18
        Tried this xtml epg again the other week seems better now than it was with the last firmware added , my question is will it go a hour out like it used to when the clocks change in march or april to bst +1 , i know it was a problem .. (one of reasons i turned it of) also with some channels having no epg at all using it .... that part of which has improved
        cheers
        • PutTheFootieOn
          • Feb 2014
          • 75
          #19
          • PutTheFootieOn
            • Feb 2014
            • 75
            #20
            Try a reflash make sure you have the correct v8 firmware unzipped onto your usb stick from the link hadron posted on the 1st page, which in your case i think will be the 2nd one down ,,, http://skybox.cc/down.asp?id=18
            • misterminibus
              • Oct 2010
              • 9
              #21
              I have replaced my F3 with an F5S and its so much better, the quality of the remote has been vastly improved and the EPG is fantastic now
              • chuckles53
                • 320
                #22
                If your having the date problem in epg just make sure your epg is up to date on your stick then put the box in standby,then take the USB stick out. Then turn the box back on with the USB stick out and when the box is up and running put the USB stick back in with the box still on and your epg should be fine. It works for me hope it works for you guys,ps I have a open box v8s with the latest firmware.
                • goldberg
                  • Jul 2013
                  • 18
                  #23
                  Anyone having problems with auto update? I have to manually update my EPG every week, auto update is set on On and I leave my box on standby every night.
                  • jc69817
                    • 138
                    #24
                    Thought this was just me Goldberg
                    Can't wait for the solution 😃👍🏼
