Openbox S9 HD PVR Linux Satellite Box
Was gonna try that and tick the bootloader option as when it crashes it says `boot` and tries for a time to start freezes then only shows `on` (with the lnb unpluged) then after being off for a while will start, but i still cant get the prog to connect to the box(serial settings are ok and its the lead i used fro my Tm1500 &5400).Comment
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the worldComment
beware of this shop, this web is dangeroushello
I have just seen an offical spainish distributor of the openbox S9.
We don't need to oder till china now .
The price is 99 euro or ?87
OpenBox Top Deco HD
ENJOYComment
ibeen using linux seens 2004 i never ever seen this shxxxxt box it dozent connect internet most of time if you modify your router this shxxxt box dozent see also pictures rubbish very very crap on my lg 3d tv look likes snowing
dont buy this crap guy waste of money pay some extra get medialink 9700 or something else fake dreambox 800 or spider 7000Comment
skysports 2sd and 4sd are the only channels on 28astra that make the box reboot with the latest firmware (20-10) i organized the hd channels on 28east and 7east and still working on the other sats. you can get the firmware from my website google 61center and go to the download section.Comment
S9 works fine for me!ibeen using linux seens 2004 i never ever seen this shxxxxt box it dozent connect internet most of time if you modify your router this shxxxt box dozent see also pictures rubbish very very crap on my lg 3d tv look likes snowing
maybe you should bin your lg 3d tv
Guys i loaded the firmware 20/10/10, scanned channels(24 sat list tried also & replace list file), but 19.2`E keeps loosing the code, if i switch to 28.2`E it is off also, restart rec and 28.2 E will stay on, but switch to 19.2` and channels loose coding.
just repluged in my eagle box with same lines and its perfect. There seems to be some glitch with 19.2E and dropping the code/lines.Comment
I just bought an openbox s9 and was wondering if anyone knows where can I download a preset channel list for 13E 19.2E and 26E as these are the sats I can get with my fixed dish.
Thanks for any help.Comment
Try this one - its 24 sats, seems quite good/stable, go into settings and turn motor off for all sats.Attached FilesComment
Ok- this seems to help a lot, if not solve the prob -Guys i loaded the firmware 20/10/10, scanned channels(24 sat list tried also & replace list file), but 19.2`E keeps loosing the code, if i switch to 28.2`E it is off also, restart rec and 28.2 E will stay on, but switch to 19.2` and channels loose coding.
Factory reset, then firmware 20/10/10, then 24 sat ch list 1.40, the replace list file, last the clines.
The box seems to need a factory reset before new firmware etc.Comment
