how can i write priority.list into openbox S9
Openbox S9 HD PVR Linux Satellite Box
Has no answer to the question, because I have the same problem?Comment
Signal Probs
Hi, my Signal on 13 E on on 12341 v/27500 and 12340h/27500 are getting weaker its not raining the weather fine ive tried to tweak it but no luck.Would a better lnb boost it?At the mo ive got a 80cm dish and my lnb can fit 4 boxes.Any idea and whats the best lnb about @ a good price.Thanks in advanceComment
Remember our rules in relation to CS discussion as already mentioned in this thread.
I have removed CWS info above, (you have it now either way), however we cannot allow c:line discussions.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
sorry about that satsmo m8 ~ I know how to setup c*cam & m*camd and lines etc on a DM, TM600 but m*camd will not work on the openbox at the moment ~ sigh !! ~ back to the TM ! ~ any suggestions by pm will helpComment
Azan m8
attached is a compilation of several tutorials ~ a few of the procedures are repeated a couple of times , but you will get the general idea. Just follow this thread back a few weeks to find the latest firmware ~ NM_HDS2_CMT_1011081100 is what I am using.Attached FilesComment
Not sure what is happening with ur recording but have u tried recording a FTA channel. If that works then not sure what ur problem is. If u get a blank screen on the FTA recording then check that ur USB device is formatted properly ie NTFS or FAT.
Remember if it is formatted as FAT then the biggest file size is 4Gb!!!!VU Solo2 (clone) , Alsat GBOX V3000 positioner, 1.8m Precision motorised dish. Invacom twin 0.3 LNB, Image Blackhole 209 clone safe. Quad core Android TV box running XBMC and many other AppslComment
