Openbox S9 HD PVR Linux Satellite Box
  • hooley
    • 470
    #286
    You might only get European sats, google legalfreetoair.com. That's an American site for the openbox.
    • olgos762
      #287
      record FTA channells
      Originally posted by buzzbomb
      Not sure what is happening with ur recording but have u tried recording a FTA channel. If that works then not sure what ur problem is. If u get a blank screen on the FTA recording then check that ur USB device is formatted properly ie NTFS or FAT.
      Remember if it is formatted as FAT then the biggest file size is 4Gb!!!!
      Record of FTA channells is ok... only for scrambled and drecypted channells is the problem...
      • pattaya
        • Nov 2010
        #288
        question
        Just ordered openbox s9 HD pvr, is it easy to set up? and does it need to be connected to the internet all the time or just for updates, sorry if this is a stupid question
        • hooley
          • 470
          #289
          it's very easy to set up, have a read back through this thread for instructions. The box dosent need to be connected to the Internet all the time. If you want to get full use of the box though you will need Internet. This can't be discussed here. Google cardsharing. Updates are done through USB
          • pattaya
            • Nov 2010
            #290
            thanks hooley,i cannot believe the welcome and helpi have recieved,will try and be an active member on here thanks again.
            • hooley
              • 470
              #291
              You're more than welcome, at least you said thanks. The amount of people who come for advice, get it and never are seen again is unreal.
              • horse236
                • 24
                #292
                itv in lanzarotie
                please can you tell me the frequncy to get itv in lanzarotie spain .i have A SKY FREE TO AIR CARD AND 2.1 METER DISH
                • hooley
                  • 470
                  #293
                  Go to king of sat, you will get all the different frequencies there.
                  • olgos762
                    #294
                    Anyone about my pvr problem??
                    • nowuckinfurries
                      • Aug 2009
                      • 111
                      #295
                      Anyone shed any light on why I have no HDMI output option ?
                      Under TV System:
                      Page 21 of the manual says I should have HDMI Video Out for setting the HDMI Video Output mode.
                      No sign of it anywhere
                      • hypersonic
                        • 254
                        #296
                        Under TV System:
                        I don't have it on mine either ~ when you start up with an HDMI connection to your TV ~ go to "video resolution" and select HD output resolution ~ ..... 720i 1080i ~ you don't get this option with a scart.
                        • nowuckinfurries
                          • Aug 2009
                          • 111
                          #297
                          Nope it's my tv thats the issue.
                          For some reason it will not play on the HDMI port for some reason.
                          I tried on my 22 inch HDMI tv and that was fine, so lead and box settings are correct. 50 inch tv plays via Hdmi from my media box fine so not sure where to go next.
                          Nwf
                          • hypersonic
                            • 254
                            #298
                            Nwf
                            Is there not a menu on your 22in TV which allows you to select various input sockets .... ie/ aux, scart1, scart2, hdmi etc ?
                            • fabmazz74
                              • Nov 2010
                              • 9
                              #299
                              Crackiling sound
                              Hi Is any one getting Crackiling sounds on bsb 28 on movies.Thanks in advance.
                              • hooley
                                • 470
                                #300
                                Sometimes I do, try changing the audio from stereo to mono channel or changing the audio out in the menu from lpcm out to bs out or the other way round I can't remember.
