openbox s9
Are you connected to tv via hd lead
KevReceivers----------OPENBOX X3
Skybox M3DM528 - PliJadeDM500s - PliJadeTechnomate TM500 - UR--------------------------------------------------------
If you like my posts press the "Thanks" button to show your appreciationComment
Yes mate connected the box to tv with a HDMI cable
Seems like I am not the only one with the problem but google hasn't found me a solution yet.
Crackling sound issue? - Openbox HD Receiver
CheersComment
Cheers
Have you got another make of hd lead to try just so we know its not the lead causing the problem
What firmware are you using? I'm on 1101030405 without this problem, either via hdmi to TV (downmixed by the telly) or optical spdif out to amp. There is some setting in the menu about digital sound I think, with 2 options to select. I have a feeling though it's something to do with turning AC3 off, which might cure your crackling, but will also remove any surround ability which kind of defeats your object probably.Attached FilesComment
Hi mate.What firmware are you using? I'm on 1101030405 without this problem, either via hdmi to TV (downmixed by the telly) or optical spdif out to amp. There is some setting in the menu about digital sound I think, with 2 options to select. I have a feeling though it's something to do with turning AC3 off, which might cure your crackling, but will also remove any surround ability which kind of defeats your object probably.
First had the problems with older firmware but they still happen with the newest firm from last month.
Yes there is two audio options but both have the problem unless I switch to non ac3 but they usually have commentary.
CheersLast edited by yhbt1mblk; 4 April, 2011, 09:08.Comment
No mate, I'm talking about an option in the Setup menu under TV System, where you can set Digital Audio Out to BS (AC3) or LPCM. If you set it to LPCM it converts a Dolby stream to PCM output. This does work as I've just tried it and watched the Dolby symbol on my amp change to PCM after changing this setting on a channel that puts out AC3 and with that soundtrack selected. As I say before, you'll lose any surround but it might mean you can watch any channel without that scratchy audio you're gettingComment
Hi mate.No mate, I'm talking about an option in the Setup menu under TV System, where you can set Digital Audio Out to BS (AC3) or LPCM. If you set it to LPCM it converts a Dolby stream to PCM output. This does work as I've just tried it and watched the Dolby symbol on my amp change to PCM after changing this setting on a channel that puts out AC3 and with that soundtrack selected. As I say before, you'll lose any surround but it might mean you can watch any channel without that scratchy audio you're getting
Switched the setting to LPCM last night but still had the same crackling sound during some scenes.
Looks like I will just have to live with it.
Cheers.Comment
Updates: 5th April 2011
Channel Update
Disney XD +1 (Frequency Change)
To continue receiving this channel the frequency will need changing
HI Kev,
How can I proceed to ENABLE english subtitle on my S 9 box?
The NEW firmware released early april, would you recommend me to go ahead and
install same on my box ?
On HD channels I noticed I do not have SOUND whereas the image is a beauty.
Thanks for your guidance.Comment
Hi, regarding subtitles just enable / disable using the sub button on the remoteHI Kev,
Hd no sound, it's not the image causing this as I've not had any problem with any image, have you had sound before with earlier images, if so just reinstall or check settings
