openbox s9
  • bernado
    • Feb 2011
    • 89
    #166
    Originally posted by omerli
    The channels section is greyed out and i cant scan.
    You access scan functions from 'Installation', the second item down on main menu. Have you looked here?
    • kevhky
      • Dec 2010
      • 153
      #167
      Hi, I have just updated the firmware you list but i have no channels now! Can you advise on how to get my channels back?
      thanking you in advance.
      Go to the settings menu and reset to default
      then upload the attached firmware below
      then upload the channel list below
      thats it all will work
      Kev
      Receivers
      OPENBOX X3
      Skybox M3
      DM528 - PliJade
      DM500s - PliJade
      Technomate TM500 - UR
      If you like my posts press the "Thanks" button to show your appreciation
      • kevhky
        • Dec 2010
        • 153
        #168
        Firmware - Favourite List - Channel Editor
        Here you go folks
        Firmware to use latest and very stable (NM_HDS2_CMT_1101030405.rar)
        Channel Sky Uk favourite list (TP_PROG.rar)
        Channel Editor (PVR 800.rar)
        Dump File Firmware and Channels in one file (as above but in one file) (HDS2_DUMP.rar )
        I currently use all these and all work perfectly, all corrupt rebooting channels are removed
        All attached
        Kev
        Receivers
        OPENBOX X3
        Skybox M3
        DM528 - PliJade
        DM500s - PliJade
        • omerli
          • Feb 2011
          • 5
          #169
          Hi,
          When i've finished uploadng the firmware ( thanks Kev ) it is asking if i want to burn the flash! should i say yes to this?
          • dell_xps
            • 2558
            #170
            Hi,
            Yes m8
            • kevhky
              • Dec 2010
              • 153
              #171
              Hi,
              Yes matey :0)
              Receivers
              OPENBOX X3
              Skybox M3
              DM528 - PliJade
              DM500s - PliJade
              • Cronus
                • 692
                #172
                Used the Sly Uk Channel list from page 7 of this thread but not all the scanned channels appear to be in the fav lists.
                Alibi and Alibi+1 are not in there. There seems to be quite a few in the scanned sat list that aren't in the favourites.
                How do I edit the channels in the scanned sat list and organise them into favourites myself?
                • dell_xps
                  • 2558
                  #173
                  Use the firmware and channel dump all in one from post 173, thanks to Kevhky !!
                  • Cronus
                    • 692
                    #174
                    Is the channel list in post 173 different to the one in post 94?
                    • dell_xps
                      • 2558
                      #175
                      Dont know m8, loaded that one up today,
                      Kev has done a great job of putting them all in order.
                      One file does it all, give it a go m8.
                      • kevhky
                        • Dec 2010
                        • 153
                        #176
                        Hi ill check my list for the alibi channels and if missing ill add them for you
                        Kev
                        Receivers
                        OPENBOX X3
                        Skybox M3
                        DM528 - PliJade
                        DM500s - PliJade
                        • Cronus
                          • 692
                          #177
                          Kev
                          I'm not complaining and I appreciate the work you've already put in.
                          If I want to delete all the channels and start again would it be better to do it manually or just do a factory reset and scan again?
                          • kevhky
                            • Dec 2010
                            • 153
                            #178
                            Factory reset
                            Receivers
                            OPENBOX X3
                            Skybox M3
                            DM528 - PliJade
                            DM500s - PliJade
                            • piranha
                              • Feb 2011
                              • 6
                              #179
                              Thanks again for the channel list, saved a lot of time. I have a couple of questions:
                              1 - I am getting glitching but only on HD channels, they were fine on the first day i used the box, but now are unwatchable, sd channels are fine.
                              2- i am getting irish tv adverts for some reason! This is happening on discovery channel and maybe others (cant remember now) Does this channel list have irish versions of the channels?
                              • ziggycat
                                • 52
                                #180
                                Here's a complete Listing.
                                1.Entertainment
                                2.Movies
                                3.Sport
                                4.Discovery & Adult
                                5.Music
                                6.Kids
                                7.Lifestyle & Shopping
                                8.News
                                Based on kevhky list, I've done a full scan on 28.2 and added all the missing channels, and rearranged everthing into the correct fav groups,.
                                Took me a while, but worth it I think
