openbox s9
Updated Sly Channel list
Ok here is the updated Sly Uk Channel list
All HD channels are now first in line in all the categories
Ive added more HD channels too many to mention with a handfull into the movie section
Added a few more adult
Also moved the channels around so best part of them follow the sky planner
I think this list is now complete and wont be altering it until Sky decide to mess around with the frequency's or new channels are added.
Regards
KevLast edited by kevhky; 5 February, 2011, 23:08.Receivers----------OPENBOX X3
Skybox M3DM528 - PliJadeDM500s - PliJadeTechnomate TM500 - UR--------------------------------------------------------
If you like my posts press the "Thanks" button to show your appreciationComment
hi guys
I dont seem to get all the sly channels through my openbox s9
a couple of cbs channels
mtv channels
none of the itv hd apart from itv1 hd
cartoon network
and a couple of others
they come up with no signal
please help
cheersComment
bit more info needed, what were you using before? I.e were you having hassle before or is this a new install. Did you load a channel list, are you using a quad lnb, could you try a different box there, or can you bring the box to a mates and test it there. These few things could narrow down your problemComment
It sounds to me you have problems with the Horizontal / Vertical signals ill look at the LNB mateReceivers----------OPENBOX X3
hi guys
my sky+hd box works fine with the sky dish and other sky boxes that are in the house old are all fine i.e getting the channelsComment
yes guys ive done reset and rescan
but i have noticed that the openbox picks up 19,13, and 28 sat using the sky dish, but they all come up with same channels just none of the above said channels
could there be a fault with the box or any sort of settings ive got to set as ive not had the box long, about 2 weeks,
using a sky dish with 8 outputs
sky+ cant record
sky+hd - cant record
2 other sky boxes that kids uses for kids and music channels
and old manhatten 3000 box
working fine with all the free channels
im hoping to replace the sky+hd box with the openbox so my partner can record her programs in HD, but she wont use it if some of her channels are not there
cheersLast edited by handyguy2002; 6 February, 2011, 18:09.Comment
Handyguy2002
Has your openbox got its own sat lead direct from your box to the lnb or are you using the loop through or a splitter as this tends to cause issues
Its best fo your openbox to have its own, if it hasnt then remive one of the leads from your sky boxes and try that im pretty much sure this is where the problem lies
I can send you a dump from my box that works perfectly
KevReceivers----------OPENBOX X3
?? thanks for your new list
