can some1 tell me how i connect my dreambox to flashfxp the dreambox has been flashed with pli jade if i go2 menu on my dream box,set up,system settings,network and get the ip address and put this in flash fxp then press connect it wont connect for some reson not sure if im doing somthing wrong any help would be nice complete novice to this sorry if it sounds silly cheers
need help conneting to flashfxp
check what your ip address is of your router and pc.
do this by clicking 'Start' on pc, 'Run', type CMD, then type ipconfig.
your 'Default gateway' is your router, your IP address is ur pc.
go into dreambox network settings and untick DHCP, manually enter in an IP address (if your pc IP is 192.168.1.2, then put ur dm ip address as 192.168.1.6, if ur pc IP is 192.168.0.2, then put ur dm ip as 192.168.0.6), save, exit and reboot ur dreamboxComment
On your FTP client try to increase the timeout value and make sure you use passive mode. Also check your firewall on the LAN on both your PC and router.Last edited by guss606; 3 May, 2011, 16:45.Comment
seanmckeown!!!
stole my ~~~~ing name cooooont!
