Lost Signal
  • packmanuk
    • Jun 2011
    • 149
    Lost Signal
    I was on 28.2 but wanted to find other sats. So I changed the setting as the ucals guide said and put in all the info.
    Now the dish moves but I can't get back to 28.2. I can move the positoner and get a lock and all seems fine but when I exit its not 28.2.
    Any ideas ?
  • packmanuk
    • Jun 2011
    • 149
    When I go to positioner and move the dish I can lock to 28.2. I then save it (or think I do) and exit the setup menu. Then when I go to watch a channel on 28.2 the dish moves to another position and the sat symbol flashed in the top corner even after the dish has stopped.
    • andy91
      • 3583
      In tuner configuration,in configuration mode choose simple.
      Mode choose positioner and put correct long and lat in,this is for usals.
      Andy.
      • packmanuk
        • Jun 2011
        • 149
        I did that and the dish moves fine. I just can't tune certain sats.
        If I search for a sat it sometimes finds it and stops othertimes goes straight past without stopping.
        I tuned 13e with no problems but can't get 28 or 19 e
        I go to positioer and lock in on the sat without problems. I then go to manual scan the sat that i'm on and everytime just before the scan it moves the dish just a bit and I can't get anything.
        Don't know what to do now.
        • andy91
          • 3583
          Maybe out of date sat xml file or are you using old bouquets?
          Can you select a strong channel like one of the fta channels on 28.2 which has a strong transponder.
          Andy.
          • bubbles69
            • Feb 2010
            • 1156
            sounds like you have put the dish well out off align this only way to get it back now is a meter to 1w and enter long and lat correclty its a bloddy hard job
            • packmanuk
              • Jun 2011
              • 149
              I can tune in to the sat using a positioner so shouldn't the alignment be ok ? I've got 19e and 13e working now.
              I get 100% signal on 28e using the positioner its when I go to scan for channels the dish for some reason moves. I get the flashing dish in the top right and it doesn't find the signal again.
              When I search for sats it sees 28e locks on but doesn't stop and goes right on by.
              Maybe I should delete all my 28e channels from yesterday and the bouquets I added and start again ?
              • packmanuk
                • Jun 2011
                • 149
                Anyone got any ideas what to try next ?
                • bubbles69
                  • Feb 2010
                  • 1156
                  yes long and lat is incorrect
                  • packmanuk
                    • Jun 2011
                    • 149
                    How do I get my exact details and which figures do I put in ? For example do I put 0 before any figures ?
                    • packmanuk
                      • Jun 2011
                      • 149
                      Can someone give me the exact figures I should put in for the postcode tq149nf ?
                        just put in your post code here m8 http://www.gaaps.com.tw/
                        • packmanuk
                          • Jun 2011
                          • 149
                          Thanks for the link but I don't see anywhere on that page to input a postcode.
                          • andy91
                            • 3583
                            Put your full address in here including your house number.
                            Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
                            Andy.
                            • packmanuk
                              • Jun 2011
                              • 149
                              Thanks for that. The settings are the exact ones I have in my machine.
                              Still nothing. Do you think I should delete the scanned channels on 28e and start again ? I can't get lots of sats like 1w or anything after about 10e really.
                              Is there anyway to adjust the dish angle without going up a ladder ?
                              I'm still not sure thats the problem though as I had 28.2 locked before I can get it again using the sat positioner. The problem is it moves to another postion when I try to watch a channel or scan, not much but enough.
