if you are NOT pressing the flash erase button on DreamUP first before flashing then your old var partition will still remain on the box's flash. press flash erase first.
I usually tend to flash via browser only.
Anytime I have done so I always log back in with the same password I had originally set and it is recognised by DCC.
Only thing I have done with a new image is to assign the same IP as the previous one.
Does the password not remain on the box regardless of a flash because otherwise how do you explain my logging in with the same password?
Its no nig deal as I will reset it to dreambox but just curious.
