no epg satmate/rytec
  • saints1
    • 91
    not been able to load epg since tuesday on satmate. keeps comming up with (sorry connection failed)! same with rytec. is there a better epg to get.
  • alom5
    • 1648
    i use open tv on crossepg. working ok.
    • saints1
      • 91
      do you need to have it on a usb?
      • The fat man
        • 196
        Opentv works through your dish
        • browno
          • 176
          how do i get this to work...need epg for sky?
          • The fat man
            • 196
            You need external storage eg USB or hdd
            Then just go into configure epg, choose opentv, then put a tick against 28.2 and 28.4
            Next press download and wait a couple of minutes and it should be done.
            Make sure you set update epg everyday in configure settings.
            I use this in conjunction with coolmans TV guide which is similar in style to the sly one.
            • browno
              • 176
              how do i configure epg?
              • The fat man
                • 196
                Once you have installed crossepg just go on it and its the first heading.
                • abr
                  • 108
                  i have tried to install crossepg
                  don't know if i have done it correctly
                  but i can't get it to download epg
                  set it to update last night and from the start to finish it took exactly 10 minutes and then no epg
                  i have not had any epg working now for a week
                  i have dreamelite blackhole image
                  i have tried rytec and satmate today and nothing downloads.
                  think the servers are down??
                  • The fat man
                    • 196
                    If you're downloading the opentv epg then its fine mine updated last night no problem.have you set the epg save path correct eg if you've got hdd you need to change options to save to hdd or USB.
                    • girovend
                      • 158
                      What image are you using ? cross epg is very easy to setup but I could never get it to work with -dreamelite-PHOENIXedition2- if thats you image then change it to something else, never had a problem on any other image
                      • abr
                        • 108
                        @ The fat man
                        i have it set to usb because thats what i have do not have h/d installed
                        @ girovend
                        the image i have is
                        DreamElite BH_DM800_133D_ssl76a.nfi.
                        it is the one before phoenix,but never had any problems with it so never changed m8
                        • abr
                          • 108
                          update:
                          i have just downloaded rytec uk on dm800
                          so it looks as if the epg servers are working again
                          • BillyBlue
                            • Feb 2010
                            • 56
                            Rytec is down again
                            Rytec is down again, Satmate hasn't worked for a while, and no other service seems to work as good as Rytec.
                            • LraiZer
                              • 126
                              upate your rytec config to latest rytec souce list?
