where do i get it,just got an image,wanna download everything before i boot my se
cross epg
Hi porter
I'm still with the 800pro, but I would say it's the same procedure. Install the cross epg plugin, reeboot, go to set up you should then go into epg config, set that up, reboot. go to the pluggin and press epg download. Hopefully that should be it. -
Dont know what image you have, but should be menu, plugins,
download plugins. You should then get to all the plugins available from your image server.Comment
No not in the image. Not sure how the menu is on the se, but must be similar to the pro. you get some plugins with the image you install, which may include the cross epg plugin. But if not you just download it yourself via the new plugins download within your menu.Comment
Yeh.....your well exited mate.. Wait for alom I'm sure he can get you up to speed quick enough.
Have you started anything on it yet?Comment
you can download it via blue button - newnigma services..onine installer or............unrar ftp to /tmp and offline install.
thee are the two..i do manual install on them.
here you go.
cccam 2.2.1 already installed and running on the image if same as me mate.Comment
