I know these are probably very stupid questions but forgive me, I am a total newbie in this field (I am an expert in other fields ;-) )
I don't understand this whole thing with images.
I used to believe that Gemini is an image, NabiloSat is an image, and Enigma is the original image that came with the Dreambox. And that when you install an image like Gemini, you replace the original Enigma image and it is no longer an Enigma OS. Or is it still Enigma OS running Gemini image?
Do I need to install an image to be able to add softcams and cardshare?
Please check this webpage No links to other forums
and tell me if this plug-in called Permanent Timeshift 0.9.3 will run on all images?
If they remove the link, please google it.
