ok got dream up and am just about to put the ip for the box in and see what happens brb..
Dreambox experts?
I take it the pin codes I gave you didnt work. Right now if you dont need any vital info from your current image then the easiest thing is to reflash via dreamup otherwise you could be pulling your hair out by midnight
Hence I dont want to complicate things too much for you.
One thing to do is take a backup of your current image just in case. YOu can do this via dreamup before your proceed to reflash.
RegardsComment
Should have also mentioned no need for ip as you are flashing via com port and null modem cable.
Hope this helps.
RegardsComment
Ok got dreaup on and yeah the pins didnt work and i thought it best to do what your saying and reflash..Hi
Regards
Hmm ive put in the ip but nothing seems to be happening?
just so i got this clear where can i find the ip for the box?
i looked on my router and saw one for it and when i try and connect it does say dreambox but....drea up is just stating to turn the box on...but it is on?Comment
ahh i see...hmmm i think i might have to get that cable thenHi
Hope this helps.
Regards
...ive got monitor cables around somewhere they look the same but im guessing not ???
Shall grab the cable from maplins?? (do they do them?)Hi
Hope this helps.
Regards
Link to the image?Comment
nice one mate!
i found some adapters that might do the trick on a monitor wire?? or is it different?
where can i get the image any idea?
checking cable now brbComment
it will work, but its hit and miss.. get a pci serial card
Startech 1 Port 16550 Serial PCI Card | Ebuyer.comFave replies from various threads
Nice one mate..it will work, but its hit and miss.. get a pci serial card
Hmm...
Is the pci card easy to install? is it just a matter of plugging it in?Comment
