Warning Sky white card burn out in Dreambox & other none Sky Receivers...
Be careful if your intending or presently using your new White Sky card in none Sky receivers the card gets very hot because the internl reader of a DM runs at 5v and the new White card is only supposed to run at 3.3v. if you notice slight pixelation of the picture on each ECM you should consider removing the card untill Voltage regulations can be addressed in any upcoming Cccam or newcs.. Its been reported by some users that cards have started burning out Its also been sugested by using external readers such as the pheonix readed can auto reduce the Voltage needed to run the card....
precautionary measure
Just be careful and perhaps remove the card at night time or deuring the day time when not in use if you consider to continue using the card in any none Sky Receiver...
I will update if I hear some more on this .....
Regards:
Alun
New diablo2cam handles 3.3v so should be ok if card inserted.
hi folks, im after getting a box key for my card to use in my tm500, but i dont have the box it came with as it went bang some months ago
is there a way from the card serial to get the box key?
MY POSTS AND ANY PM`S ARE PURELY FOR EDUCATIONAL AND LEARNING PURPOSES
I AM FULLY RESPONSIBLE FOR MY OWN POSTS, MY POSTS ARE NOT CONDONED, MODERATED OR AUTHORISED BY ANY MEMBER OF STAFF ON THIS SITE AND I TAKE FULL RESPONSIBILITY FOR ANY CONTENT CONTAINED IN MY POSTS OR LINKED TO EXTERNALLY.
how abouts getting another sky box and ringing sky to pair the card to it for you. then you can getthe box key. then give back the box to wherever or keep it for future use.
