here we go i had my dreambox 800hd with dreamelite v.3 top channels set up looking and working great THEN i did a little manual scan onday and now some how all my sat sattings or all mesed up i didnt bak up my system and after spending 2 days now i cant for my life remmember how i set my tuner settings up. i couldnt get mine working through simple settings i had to go in advance set up
tunar a.alps bsbe2 (dvb-s2)
'what sat do i set this too first '
lnb1
universal lnb
polarization
yes
band
1.2
then down too and changed mt longi and latty bye the way was slightly different to what it should be?
then set usuals to YES
I NEED TO KNOW WHAT ORDER TO DO THINGs MEANING do i set this first then do i need to use satfinder or positioner setup
in sat finder is tune set to manual or predefind ? what satellite should it be on ?
and in positioner setup what do i tune too manual or predifined do i only do this once my dish seems to only move in predifind
i was told of the installer to set my dish first to thor 8w once found set the rest UP what does that meen ? he is african origan i have trouble on the phone comunicating with him
i did that found a picture then when i choose another sat my dish does move but goes past the signal?
or am i as usual doing everything wrong i hope someone can lead me down the right path with detailed set thanks for reading les
lnb1
universal lnb
polarization
yes
band
1.2
If you put full address here you will get an accurate long and lat but it aint massively important, Andy
