Dreambox streaming to internet,it was never easy like this
  • sirsmooth
    • Aug 2009
    • 9
    #256
    Ok, I found the reason for my odd IP during internal port scan. It was my vmware,
    My IP shows correctly now:
    My DNS is also fine:
    I am still unable to stream over the net!
    I have well and truly run out of ideas
    Any other ideas?
    Thanks Gaz
    • mfaraj57
      • 557
      #257
      Any other ideas?
      Thanks Gaz
      Hi
      Ok,sometimes altough you see the video in restreaming window actually no streaming occurs
      be sure you are streaming by lower preview button
      you can try several things as rebooting router,rebooting pc ..etc
      did you open port 5678 and forward it to local pc ip
      open it and i will to connect with your streamer from here .
      block firewall and try again
      even you have static ip try to assign dns address
      try also to forward port 80 to ipdream and see what happen when you put your static ip in internet explorer
      others reach this point and and when they start to give up streaming occurs!
      be sure you have vlc .99 although latest program update accept the versions 1.0.0 and 1.01
      by try first with vlc .99
      choose your intenet profile from low to high and leave advanced setting later and do not forget to uncheck "receive stream by mobile"
      use th last update coud solve the problem
      Tunisia-sat dreambox player and webstreamer 5.0.7
      • mfaraj57
        • 557
        #258
        Hi
        it is working now
        sorry i could not catch the picture by screencapture program
        you can choose low or medium internet profile settings
        • mfaraj57
          • 557
          #259
          Hi
          The video is continuous but the picture is blurred due to low upload profile settings
          • sirsmooth
            • Aug 2009
            • 9
            #260
            Thats very odd, I am unable to preiview my stream.
            I am unable to test on my Pc or laptop yet it works for you?
            I am trying to use vlc to recieve the picture , what tool do you think is best to receive teh stream? (to pass onto friends)
            Thanks for all this help.
            Gaz
            • mfaraj57
              • 557
              #261
              Hi
              Now you can play with advanced settings and choose different compinations to stream better
              our freinds above suggested good compinations
              regards
              • mfaraj57
                • 557
                #262
                Gaz
                hi
                sometimes there is block to view locally for reason i do not know
                your friends can use wmp or vlc
                but they shoud add "h" when receive mms (mmsh) when use vlc to receive stream and to use vlc for http
                you can use dreambox web receiver for complete control of streamer program and to switch channels
                • sirsmooth
                  • Aug 2009
                  • 9
                  #263
                  Whats the latest version of this and where can I get it?
                  • mfaraj57
                    • 557
                    #264
                    Tunisia-sat dreambox web receiver 5.02
                    You can test it in same pc with streamer-server program running
                    just fill your dns or static ip in settings
                    used to control streamer-server program remotely and accordingly control dm
                    you can start stream,stop stream,switching channels and even start recording remotely
                    the pictures in post 59 and 61 above are for the web receiver program which looks like the streamer one but has green interface
                    regards
                    • sirsmooth
                      • Aug 2009
                      • 9
                      #265
                      Thanks for the link.
                      I am having a problem trying to stream anything with the h264 setting, all I get is crashes just like post #205
                      No matter what othersettings I use with h264 it always crashes.
                      What is the best h264 codec to use, is there a codec 'pack' with everything in by any chance?
                      Also you say to use http with the h264 codec put people are posting settings using mmsh.
                      By the way I am having internet problems at the moment so my download is as fast as my upload, 376k!
                      But download is only really needed by the receiver correct?
                      thanks again!
                      Gaz
                      • mfaraj57
                        • 557
                        #266
                        thanks again!
                        Gaz
                        hi
                        Your upload 370 kb/s nearly good and download speed important to who receive the stream
                        the program crashes when h264 used and this is expected with version .99 vlc and this is known bug in vlc
                        download version vlc 1.0.0 or 1.0.1 and both work with h264 codec
                        regards
                        • sirsmooth
                          • Aug 2009
                          • 9
                          #267
                          Once again you have sorted the problem for me
                          I can see the error message that I am unable to connect to my dns when I test locally (over internet - top preview) with the new version
                          • mfaraj57
                            • 557
                            #268
                            Hi
                            This feature added in
                            • patje30
                              • 5
                              #269
                              Hi,
                              First of all I would like to congratulate you with your excellent program. I've got the program started, but when it loads on vlc, after 5 seconds it stops again and goes back to the normal playing dreambox tv. What can I do about it?
                              Greetings
                              • mfaraj57
                                • 557
                                #270
                                Originally posted by patje30
                                Hi,
                                Greetings
                                Hi
                                what version of program you are using
                                version 5 only accept vlc.99
                                version 5.0.7 accept vlc .99,1.0.0 and 1.0.1
                                download latest version build and and use recent version of vlc
                                Also this behavior can occur with dreambox loaded with images other than pli-jade and sifteam(e.g gemini)
