Dreambox streaming to internet,it was never easy like this
  • mfaraj57
    • 557
    #106
    Originally posted by dowlinr
    I had troubles with this on my laptop. I loaded it on my pc and it works but there are a few bugs (which I can live with).
    When I change the channel on my dreambox it reconnects to the stream but loses sound. I have to restart the app before sound works again.
    Another issue I have is my bouquets start with Astra 28.2e which is empty, then I have UK tv which starts with bbc1, bbc2 etc. The app seems to have added a random bouquet called 2AE which now has all the channels that should be in UKTV. UKTV now has sky movies channels, sky sports are now in my movies bouquet etc.
    This bouquet issue also happened in Dreambox viewer ver 4.0
    In all I am very impressed with the app, very good work Mfaraj
    Thanks dowlinr
    thanks also for nice pictures and demonstration
    Typically changing channels should be from application itself,however if user changes channel from the receiver the app understands that and accomdate accordingly but may behave differently in state of streaming and recording
    regarding the bouquet 2AE,the app does not add anything,The program connectes with dreambox database and brings channels and bouquets information and displays them. About the appearance of 2AE which it seems shorcut for 19.2 astra east
    i will investigate that and i will fix the problems you have faced in next version
    The program is individual effort and tested in one enviroment so bugs are expected with different enviroments
    thanks again for your positive notes
    watch live stream from my dreamboxes
    • dowlinr
      • 226
      #107
      Originally posted by mfaraj57
      Thanks dowlinr
      I tested it on my laptop and desktop, both showed the 2AE so it may be an issue with my dreambox config. The webinterface for the dreambox shows the bouquets as they are in the channel list on my dreambox so not sure if it is a failure on my part setting up the bouquets or a bug in the software.
      If you need my services and bouquets files i'll zip them and upload them somewhere.
      On the channel change issue I was using the remote control, haven't tested changing channel with the receiver software as I was testing with windows media player only.
      • mfaraj57
        • 557
        #108
        Hi dowlinr
        It is important to me to have the services and bouqeuts files to study then
        please upload them anywhere and pm the link
        • .: JaCkPoT :.
          Retired Sat TV Addict
          • 5607
          #109
          cheers stream worked...im no too bathered about the quality man..nice one
          ___________________
          In the good old days, I had
          DM800s HD
          Openbox S10
          TM500
          DM500s
          90cm FortecStar dish
          Maxx 110cm Dish
          Technomate 2300 Motors
          • mfaraj57
            • 557
            #110
            This stream by upload speed 90kb/s imagine if it is 400kb/s
            the quality with improve ten times
            • mfaraj57
              • 557
              #111
              Do you receive the stream,now just changed the internspeed to medium from settings,the quality will improve but with inturruption
              • .: JaCkPoT :.
                • 5607
                #112
                screenshot doesnt work
                ScreenShot doesnt work, when i press 'Print Screen' the little screen turns all black for the screen shot. i have tried over and over again..
                ___________________
                DM800s HD
                Openbox S10
                TM500
                DM500s
                Maxx 110cm Dish
                • mfaraj57
                  • 557
                  #113
                  Ok do not worry
                  this behavior expected with windows media player hard acceleration put to full
                  to make print screen working and screenshot just by right mouse click on small screen-options-decrease hardware acceleation to half and everything with be ok
                  • mfaraj57
                    • 557
                    #114
                    • mfaraj57
                      • 557
                      #115
                      for taking screenshots and adding texts to picture i advice this nice programsnagit
                      pictures above taken from snagit
                      second good program to upload images
                      attached with this post
                      just drag the picture you want to the frog and after seconds will give you the link
                      Watch streaming from dreambox by internet
                      • mfaraj57
                        • 557
                        #116
                        Hi
                        The problem in first item
                        Astra/eurobird-28,2AE
                        the comma inside the item make the program to understand this as two bouquets so add 2AE
                        this rare bug in program and will fixed in next version
                        for now to fix it,just from receiver remove the comma(,) from the item and everything will be correct
                        • gurr
                          #117
                          ^^ i noticed the same bug
                          • mfaraj57
                            • 557
                            #118
                            Yes it is bug
                            when i observed the name of bouquets for presence of comma and i did not find it
                            but the expresion 28,2AE should be written 28.2AE but this error cause minor bug in my program
                            solution just remove "," from the 28,2AE from receiver or from dreamset and everything will be ok
                            • dowlinr
                              • 226
                              #119
                              Yes it is bug
                              Mfaraj is right, simply changing the comma for a full stop fixed this bug for me.
                              • MyB5
                                • 49
                                #120
                                Anyone has this working with Vista Home Premium (streaming)? I'm just able to watch it on my PC (Lan)....
                                Vu+ Duo-BH 2.0.9,1
                                CloudIbox II+
                                DM600PVR & DM500
                                Skybox F5 & F5s
                                Oscam 9533 & CCcam 2.2.1
                                0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
                                Scandinavian
