Dreambox streaming to internet,it was never easy like this
  • mfaraj57
    • 557
    #541
    Happy to hear that
    you can play with codec settings from advanced settings in settings page to improve your internet streaming
    regrads
    • skywalker2
      streaming local ok, streaming to inet nok
      Hi mfaraj57, first of all, thanks for your great job. Well I install Dreambox player and streamer 6.1.0 in W7. I open 1234 and 5678 as instruccions says for pc ip. And port 80 for dreambox ip. The program plays well. When I start streaming the local preview works well, but the stream internet adress don't work. The preview says conection time out. Could you helpme on this? what's wrong? Thanks in advanced.
      • mpro
        Hi mfaraj57
        Many thanks for your software and development. I've discovered your work in an article published in the Magazine What Satellite (August 2010):
        Dreambox remote video streaming
        Using your "Dreambox player and Streamer 6.04" It was easy to stream DM500 channels into internet and intranet.
        Best regards
        and good work
        • fernandoch
          • 7
          #544
          Hello,
          I am using version 6.1.0 with my dreambox 800. It just works for 10 seconds or so and then it stops. I am using vista and vlc 0.99
          Any ideas about what could be wrong?
          I am also using a wifi connection... Could that be the problem?
          • albert.shepherd
            • Oct 2008
            • 9
            #545
            Streaming with Dreambox
            I had that using the Gemini image on the dreambox--changed to PLi Jade image and VLC 1.0.5 and it cured everything.
            Used Jade just as it came no setting to do other than activating CCcam for my cardxxxxxxxing
            • fernandoch
              • 7
              #546
              So that means it only works with a pli jade image?
              I am used to nabilosat images
              • mfaraj57
                • 557
                #547
                you have to check dns address and if it is active
                enter dns address in internet explorer assuming the port 80 forwarded to dreambox ip you should see what called dreambox webinterface,else there is something wrong in dns
                also you can check for dns adddress from the program settings
                • mfaraj57
                  • 557
                  #548
                  Originally posted by mpro
                  Hi mfaraj57
                  Best regards
                  and good work
                  Thanks for info
                  good guide for internet streaming by using this program
                  this is the complete article
                  project+-+dreambox+remote+video+streaming.pdf
                  • mfaraj57
                    • 557
                    #549
                    Originally posted by fernandoch
                    Hello,
                    Hello
                    the problem could be either to weak dreambox streaming to pc(wifi) or bad codec setting from program settings
                    some channels from dreambox send weak stream,try with different channel
                    • mfaraj57
                      • 557
                      #550
                      locally with any enigma1 image works but for remote streaming found pli jade is best
                      • albert.shepherd
                        • Oct 2008
                        • 9
                        #551
                        I am fairly new to this so I have only tried Gemini and PLi Jade and was worried about changing because of cardsxxxxxing but it worked fine I have not tred the image you mention
                        • fernandoch
                          • 7
                          #552
                          Originally posted by mfaraj57
                          Hello
                          I tried with another channel and still the same, it works for 10 seconds and stops... What do you mean by bad codec? I am using vlc 0.99 as you suggested.
                          • albert.shepherd
                            • Oct 2008
                            • 9
                            #553
                            Hi
                            Any thoughts why the install of the same file WebPlayer/sreamer 6.1 on two different pc's that one shows "stream to mobile phone" and the install on a diferent machine does not show the option.
                            Both pc's running Windows 7 Home Premium.
                            Sorry about that it was in the advance mode.
                            Any thought s on "unsupported content" being returned by my mobile phone or am I really pushing my luck.
                            Many thanks
                            • mfaraj57
                              • 557
                              #554
                              codec constitutes of the streaming parameters you have chosen for stream ,by other way streaming needs to be compressed and transcoded to be handled by internet route so you should decide what is appropriate for your internet speed
                              from program settings you have three presets values for codec according to internet upload speed you have low,medium and high and further more you have advanced which you can go more depth in details but you should have minimal knowledge how to combine different parameters
                              stopping of the streaming after few seconds could be issue for dream image,dreambox connection to router(wired or wireless) or improper codec(choose one from presets values-start by low )
                              could upgrading your vlc version more than .99 solve the problem if your windows language is English
                              • mfaraj57
                                • 557
                                #555
                                Originally posted by albert.shepherd
                                Hi
                                Many thanks
                                yes "stream to mobile phone" disappear when you choose advanced mode because no need for that because in advanced mode you should choose what appropriate for mobiles to receive streams
                                to receive stream through mobile,your mobile should have either vlc4iphone for iphone or coreplayer for nokia,my experience with other players are discouraging as example realplayer is not good to receive stream
