Dreambox streaming to internet,it was never easy like this
  • mfaraj57
    • 557
    #601
    Originally posted by gravesdk
    Please help, I am using win7 32 bit and dm 500s. I loaded pli jade image but I have sound problem. Image is fine with mfaraj viewer 6.0.4 but no sound with many channels.. Do you have any idea to solve this problem? (VLC version is 0.9.9)
    usually this problem from performance of image in dream(loaded memory),load fresh image may solve the problem
    • NaNaNiii
      • Dec 2010
      • 167
      #602
      Hi Mfaraj, I can steam to one person no probs but steaming to more than one, my bandwith cant handle. I have a Giga server. Is it possible to stream to the server and then restream from there in order to stream to multiple people? Thanks
      • Alibegovic
        • 11
        #603
        Mfaraj, is there a possibility that you incorporate DVB subtitles in later versions, that would be great.
        • wohey
          • Feb 2011
          Originally posted by mfaraj57
          hi
          just for test just extract the exe to program folder no need fo setup
          more flexibility in chosing upload speed and more advanced options
          Is it possible to change the use of Mediaplayer to VLC?
          Thanks!
          • mfaraj57
            • 557
            #605
            usually you can stream up to 5 persons without problem
            but theoretically you can stream to server and restream again but practically the restream quality will not be so good
            • mfaraj57
              • 557
              #606
              may be considered but this project took alot of time from me and i am planning to publish source code,could someone develop it more
              • mfaraj57
                • 557
                #607
                Thanks!
                i am using windows media player and bitcontrol codec for receiving stream from enigma1 dreambox(more stable)
                for enigma2 and and restreaming i am using vlc
                • manhatten
                  • 49
                  #608
                  Hi I have it working fine on my local network, Was using darkstar image that was fine, But after reading I changed to OpenPLi-beta-dm500-maxvar that is also working good,
                  Now I am trying to stream on the net, I have started the first stage of adding the info into my router for port 80 the answer I am getting is (service port No was defined by another service)
                  can I use another port No for this first stage.
                  Win XP Router Netgear Dg834g.
                  Thanks for any help
                  • tkm18
                    • Aug 2009
                    • 158
                    #609
                    Im stumped, got an older version of tunisia running, streaming to justintv ok, but wont stream across the internet, got 2 other laptops not streaming across the internet, but all are ok with local streaming.
                    Now im assuming the dns settings are ok as the older tunisia is streaming to justintv.
                    Any ideas. .
                    TIA.
                    • user68
                      • Apr 2010
                      • 4
                      #610
                      I've been using version 6.1 successfully on Windows 7 but now want to run it on XP Pro in Virtualbox on Ubuntu 10.04. I've not been able to get it working this way yet. Is there any reason why it couldn't work in Virtualbox?
                      Although it appears to be streaming, I don't see any picture in the viewing window but if I tick "Restream by vlc player" then I see a picture. The port forwarding is a problem too with the private address given by Virtualbox in the range 10.0.2.x
                      Does anyone have experience of using DB Player and Streamer in Virtualbox?
                      • NaNaNiii
                        • Dec 2010
                        • 167
                        #611
                        Hi
                        I cant seem to get streaming to JTV working. The VLC Window pops up however in CMD i get this error:
                        Error 102: Could not find or access the file c:\dreambox\vlc.sdp
                        • simbad16
                          • Feb 2011
                          • 6
                          #612
                          big thanks to mfaraj57 for his work and time.
                          i had tried this in the past but gave up my fault.
                          i have
                          windows xp pro
                          vlc vlc-0.9.9-win32
                          dm500 pli jade
                          i cant even instal the program this time round :-/
                          i did delete the HKEY as advised
                          in the download i have
                          player
                          setup
                          setup.lst
                          when i try setup i get the following messageat stage 7
                          "setup cannot continue because some system files are out of date on your system. click ok if you would like setup to update these files for you now. you will need to restart windows before you can run setup again. cancel to exit setup without updating system files."
                          i did try ok and pc rebooted but nothing!
                          inside folder i see many icons portscanner works and port checker.
                          please help, what do i need to do to install on pc.
                          • user68
                            • Apr 2010
                            • 4
                            #613
                            @Simbad
                            I solved this problem by opening Setup.lst in Notepad then putting ; in front of some lines under the [Bootstrap Files] heading. From memory, I think it was
                            [email protected],$(WinSysPathSysFile),$(DLLSelf Register),,3/5/10 10:42:42 AM,67584,6.1.7600.16544
                            [email protected],$(WinSysPathSysFile),$(DLLSelf Register),,7/14/09 4:16:12 AM,90112,6.1.7600.16385
                            [email protected],$(WinSysPathSysFile),$(DLLSelf Register),,4/7/10 10:10:36 AM,571904,6.1.7600.16567
                            [email protected],$(WinSysPathSysFile),$(DLLSelf Register),,7/14/09 4:15:50 AM,1386496,6.0.98.15
                            I changed these to
                            ;[email protected],$(WinSysPathSysFile),$(DLLSel fRegister),,3/5/10 10:42:42 AM,67584,6.1.7600.16544
                            ;[email protected],$(WinSysPathSysFile),$(DLLSel fRegister),,7/14/09 4:16:12 AM,90112,6.1.7600.16385
                            ;[email protected],$(WinSysPathSysFile),$(DLLSel fRegister),,4/7/10 10:10:36 AM,571904,6.1.7600.16567
                            ;[email protected],$(WinSysPathSysFile),$(DLLSel fRegister),,7/14/09 4:15:50 AM,1386496,6.0.98.15
                            Everything installed OK after that. If anyone knows a better way, please let me know.
                            • simbad16
                              • Feb 2011
                              • 6
                              #614
                              wow well impressed went on ms site for help loads of crap from there.
                              that sorted it out!
                              my 1st hurdle over will continue
                              thanks again
                              another funny thing it is now installed but i can't open program egg timer come on a sec and nothing, not to worry pc is need of a format so may resort to that over the weekend.
                              could this have something to do with my previous installation?
                              • simbad16
                                • Feb 2011
                                • 6
                                #615
                                Ok reformated pc which was well over due any way.
                                installed again and up and running 1st tie in in less than 5mins yey
                                thanks a lot
