Dreambox streaming to internet,it was never easy like this
  • kamel22
    • Jun 2009
    • 42
    #466
    Originally posted by mfaraj57
    Hi and sorry for delay
    to receive stream we can use vlc,wmp or web receiver program
    in vlc we can put in file-open netwrok stream and put the address appeared in streamer program
    in wmp you can use file-open url and put the address
    regarding web receiver just fill the dns address and port 1234 in settings
    you can do this and test in streamer side and see if you receive stream,if you succeeded in receiving streaminm in same windows hosting streamer and you can not receive in remote vista pc then there is problem in vista and program
    regards
    hi mfaraj57, thank you for the respose.I tried the above settings but to no avail. dont know whats wrong.i tested it on my windows xp where i installed your program.
    Results:
    vlc-it says unable to open the MRL http://192.168.x.xxx:xxxx
    wmp-it says unable to establish a connection to server.(mms://dyns.com:1234)
    please help. port 1234 and 5678 are open. again thanks in advance.
    • mfaraj57
      • 557
      #467
      Results:
      There are preview buttons in right lower side of program,what happaned when press them
      can you attach picture for the program during streaming
      regards
      • kamel22
        • Jun 2009
        • 42
        #468
        hi mfaraj, my problem at the moment is that i cannot stream to my pc where i installed program 6.04 and 5.02.ports1234 opened and dns updated. program 6.04 working well but 5.02 can not receive streaming it only says streaming wait.. i can see all channels but thats all.I think the question is what shall i do to make 5.02 to work or am i missing something.again thanks.
        • mfaraj57
          • 557
          #469
          hi
          these are the typical settings
          • kamel22
            • Jun 2009
            • 42
            #470
            hi mfaraj57, i down loaded the program 6.04 several times last night and all the program does not have a preview button i don,t know why. is there something wrong with the program. all i can see was audio language and the volume icon on the right lower area.also every time i press streaming it says invalid procedure or argument. can you check the download on your first post please.i cant seems to make this work.thanks.
            • kamel22
              • Jun 2009
              • 42
              #471
              any update mr.mfaraj57.thanks.
              • djrobbie
                • Mar 2010
                • 14
                #472
                Hello!
                I'm back
                Still using the Dreambox VLC Streamer 1.2 and it works perfectly!
                But still cant figure out why VLC wont show the "transcoded video" when Dreambox VLC Streamer 1.2 calls VLC for transcoding. VLC just opens and transcode it.
                In your program, users can view the transcoded picture.
                Whats the difference in the calling for VLC?
                • mfaraj57
                  • 557
                  #473
                  i will check version 6.0.4 for this error,however you can use 6.0.3 no much difference
                  regards
                  • mfaraj57
                    • 557
                    #474
                    Originally posted by djrobbie
                    Hello!
                    I'm back
                    Hi djrobbie,nice to hear from you
                    Both programs use same technique in restreaming and i will not convinced that one better than the other in restreaming because both using vlc
                    my program hosts vlc plugin so transcoded steam shown in my program
                    regards
                    • kamel22
                      • Jun 2009
                      • 42
                      #475
                      hi mfaraj57,
                      I tried to run the program 6.04 on my vista(lap top) but can not open the program "error accessing OLE registry" how will i open the program using vista.please help.thanks.
                      • mfaraj57
                        • 557
                        #476
                        hi mfaraj57,
                        sorry for delay in response because net problem
                        usually this can be solved by run as administrater or choose xp compatibilty mode and same in windows 7
                        • djrobbie
                          • Mar 2010
                          • 14
                          #477
                          Hey!
                          When it comes to embeding the stream in my homepage. You sent me a code once. It works perfectly!
                          But, is there a way to design it more? I want to change the text PLAYLIST1 that comes as default in the embeded wmp.
                          Is it also possible to use an ASX file instead of the code you sent?
                          The code you sent was:
                          PHP Code:
                          <p style="text-align: center;"><span> </span><object classid="clsid:6bf52a52-394a-11d3-b153-00c04f79faa6" width="368" height="294" codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=5,1,52,701"><param name="Title" value="MediaPlayer" /><param name="url" value="mms://YOUR IP:PORT" /><param name="src" value="mms://YOUR IP:PORT" /><param name="name" value="MediaPlayer" /><embed type="application/x-mplayer2" width="368" height="294" src="mms://YOUR IP:PORT" name="MediaPlayer" url="mms://YOUR IP:PORT" test="MediaPlayer"></embed></object>
                          • kamel22
                            • Jun 2009
                            • 42
                            #478
                            Hi mfaraj57, i am still having problem in opening program 6.0.4 with vista. i tried administrator and compatibility windows xp but to no avail. Anyway the good thing is i managed to stream using program 5.0.5 and very happy with it. thank you for the time and help you provided.keep up the good work. for now i,ll just enjoy this program and hopefully find the way to open 6.0.4. again thank you.you,re a star.
                            • mfaraj57
                              • 557
                              #479
                              Thanks for you
                              difference between 5.0.5 and 6.0.4 later is portable
                              i will prepare complete setup program for 6.0.4 and put link n first post
                              regards
                              • nabat
                                • Mar 2010
                                • 10
                                #480
                                Hi mfaraj57,
                                Can you please help me with a strange problem
                                when I choose the advance option for upload profile and press restream , the address which results starts with MMSH or HTTP, I copy the full address and paste it in url of windows media player, the player rejects both addresses that start with MMSH and HTTP.
                                please help me how to solve this problem
                                Thank you in advance
