Signal Level. Can?t get it higher than 20%
  • NewBirth2010
    • 56
    Hi guys,
    My Dreambox set up seems to suffer from bad signal reception. I pointed my 90cm dish to the Hotbird Satellite and I get only 20% of signal, measured by the ?Satfinder? option in Dreambox. I was trying for 3 hours to position the dish to the right direction but I could not get anything better than 20% of signal.
    I used a multi-meter to measure the voltage on the edge of the F-Connector before the LNB and I got 18 Volts. Other than that I can not think anything better. There are trees, at the left and right of the Dish and Live Electric Wires passing at 80 degrees above the Dish but they don?t obstruct the clear view of the satellite.
    What do you think is the reason why I am getting such a poor signal level?
    I have been a bit obsessed with this problem , so please, if you know something, don?t skip this thread.
    Michael
  • westkill
    • 2378
    is this a motorised setup or fixed
    what box you using
    • NewBirth2010
      • 56
      Hi westkill. It is a single LNB and dish on A Dreambox 800 HD.
      Thanks in advance.
      Michael
      • westkill
        • 2378
        what image you using in your box ...?
        how have you setup your tuner configration
        is the elivation of the dish ok meaning up and down on the bracket if you no what i mean
        • NewBirth2010
          • 56
          Hi westkill and thanks for the interest.
          I am using the original /preloaded Enigma2 image.
          Settings are:
          Configuration Mode: Advanced
          Satellite: Hotbird (13.0E)
          Voltage Mode: Polarization
          Tone Mode: Band
          DiseqC Mode: None
          LOF: Universal LNB
          Increased Voltage: No
          Any ideas Please?
          Michael
          • opsmonkey
            • 5379
            sounds like your dish isn't lined up to hotbird properly..
            how did you originally lock on to the satellite..??
            • .: JaCkPoT :.
              Retired Sat TV Addict
              • 5611
              What to you is get a channel list for hotbird, then goto to one of the channels thereafter alter your dishes alignment until you get a picture. Look at the sky dishes of your neighbours and get a brief of the elevation required but for hotbird it will be everSo slightly higher due to it being closer to the due south satellite here in the uk.
              ___________________
              In the good old days, I had
              DM800s HD
              Openbox S10
              TM500
              DM500s
              90cm FortecStar dish
              Maxx 110cm Dish
              Technomate 2300 Motors
              • nexus_oz
                • Jun 2009
                The satfind option in setup seems to be slow to respond. I have a dm7000 and dm7020. I found the dm7020 pli image has a plugin also called satfind.
                It only outputs to the lcd and has ber as well as snr and agc. It updates much faster. So much so that the last 2 digits of the 5digit numbers for snr and agc are a blur.
                I'd suggest tying to get that plugin. Also one of those simple sat meters that has a needle and dial, audible tone and gain control are simple to use but can get you very close to a good signal.
                • dazmaul
                  • Mar 2009
                  • 61
                  It's your image mate.
                  I had the same problem with my DM800. I think it came with Gemini 3.90 pre-loaded on it and signal strength was showing as no higher than 24% - I had no end of problems and ended up flashing Gemini 4.10 to it and the signal strength is somewhere between 70-90% - without moving the dish.
                  • NewBirth2010
                    • 56
                    Dear Dazmaul, Please Stay with me!
                    This is exactly what I get. Maximum signal at 24%. Exactly the same rate as you stated.
                    But it looks like I don't have Gemini image installed but the Enigma2 image.
                    Anyway thanks for putting me in the right direction. It sticks exactly at 24% !
                    Ohhh man thanks ! You saved me a lot of brain ! Thanks!
                    If it is the DreamBox unit please tell me so I can take it back (it will be a pain for me though, because that was the last unit stocked in that shop)
                    Thanks Again
                    M.
                    • westkill
                      • 2378
                      ive had a low signal on some images but if picture is fine and no pixalation on all your channels dont worry
                      • dazmaul
                        • Mar 2009
                        • 61
                        Enigma2 image?
                        If you select the MENU button your remote and then INFORMATION... ABOUT... there are two dates IMAGE: ENIGMA: - what dates do you have? What logo is displayed?
                        • ajandali
                          check you LNB
                          • NewBirth2010
                            • 56
                            Originally posted by ajandali
                            check you LNB
                            Ohhh yeah right! Why haven?t I thought about it before?
                            But there is also another guy who gives such wonderful advices that look so wonderfully identical to yours, here:
                            I bet, soon you will both become admins !
                            Michael
