Tring Card read directly in CCcam 2.1.3
  • 215liverpool
    • 69
    Hi there,
    I have read that a Tring card can be directly read in CCcam 2.1.3 without NewCS.
    Does anyone know if this is true as I have tried it but I haven't had any luck.
    Many Thanks
  • opsmonkey
    • 5379
    if your running the correct 2.1.3 and not the earlier fake editions then if your card wont open then no..
    have you checked your entitlements tab..?
    open your web browser, in the address bar type in your dreambox ip address then :16001
    eg..
    192.168.1.5:16001
    The webpage that open should read..
    "Welcome to CCcam 2.1.2 server"
    Click on the entitlements tab.. what does it say
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5611
      It should say, welcome to cccam 2.1.3 server.
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • opsmonkey
        • 5379
        ha ha yes it should.. that was a cut and paster from mine
        • 2tone
          • 483
          think it still only reads by newcs+cccam would be nice but
          • 215liverpool
            • 69
            eg..
            192.168.1.5:16001
            Hi there
            I get
            card reader /dev/sci0
            no or unknown card inserted
            So I'm guessing it can't read the card if it says that.
            All I'm trying to do is get my Tring Card to update it's entitlements each month. I can get it to read the card in NewCS /CCcam but it doesn't update each month. I can't get NewCS/Mgcamd working and I'm told that's the only combination that can update the Tring card each month.
            Can anyone else please offer any solutions ? LOL
            I have a DM800 so I can't insert an official Conax CAM because there isn't a CI slot in a DM800.
            Regards
            • Manic01
              • 5117
              newcs 1.20
              • Manic01
                • 5117
                on f ;line to peers you must do F: user pass 1 0 1
                the last one is to get emms from peers
                • 215liverpool
                  • 69
                  Apologies for being dense but does this mean I will get my card updated each month from other people on my shares.
                  • opsmonkey
                    • 5379
                    no mate you need to update your own card.. for instance Sky cards need to go into an official sky receiver to update.. i'm not sure if the same goes for a Tring card
                    If NewCS/Mgcamd is the only way to update it in your D800 then you'll have to get a grip of its workings mate otherwise your card will not update..
                    hopefully someone who uses NewCS/Mgcamd will be able to help you out further..
                    Your best bet might be to check out some of the dedicated card sharing forums.. google 'cardsharing forum' for more info
                    • firestorm
                      • 1550
                      my tring card update no problem with Cccam\newcs i had to use a conax cam to first active the card.now all i have to do is leave it on tring supper and it update
                      • Manic01
                        • 5117
                        Card will update via peers if dish is not used on 16e. That config will allow others who cs to update for you.
                        • firestorm
                          • 1550
                          you need to have
                          <au>on</au>
                          in your newcs.xml file for this to work
                          • 215liverpool
                            • 69
                            Hi there
                            Can I ask which versions of NewCS and CCcam that you use ?
                            • 215liverpool
                              • 69
                              Sorry guys now I'm confused
                              opsmonkey mentioned that the only way to update is for me to update my own card.
                              Now Ferona mentions that by having the f lines set as F: user pass 1 0 1 it will update my card through my peers. Ferona I assume you mean my F lines in my CCcam config file.
                              I new to using the Tring card in a Dreambox so I appreciate your help !
