looking for sat xml file for dream thxs
satellite xml
Satellite Pos. Freq. Pol. SR FEC Name update Date BEAM Provider DVB
Eutelsat W2A 10.0?E 10714 V 3255 5/6 Channel 11 feeds new 24.01.2010 Europe
Express AM 22 53.0?E 12736 H 2592 3/4 feeds new 24.01.2010 S2
Intelsat 905 24.5?W 11066 V 3980 3/4 Testings new 24.01.2010 Spot1
Intelsat 905 24.5?W 11603 V 17220 3/4 data service SR 24.01.2010 Spot1 S2-8PSK
Turksat 1C 31.0?E 10994 V 2170 3/4 AKS TIMO feeds new 24.01.2010 west
Turksat 1C 31.0?E 10999 V 2200 3/4 D?ğ?n TV Freq 24.01.2010 west1C D?ğ?n TV
Turksat 1C 31.0?E 11002 V 2222 5/6 feeds FEC 24.01.2010 west1C
T?rksat 2A/3A 42.0?E 10958 H 2222 5/6 feeds new 25.09.2009 East3A
T?rksat 2A/3A 42.0?E 11156 H 4444 5/6 feeds new 24.01.2010 West3A
T?rksat 2A/3A 42.0?E 11168 V 6666 5/6 feeds new 24.01.2010 West3A
T?rksat 2A/3A 42.0?E 11465 H 14578 1/2 data service FEC/SR 24.01.2010 East3A SkyARCS S2-8PSK
T?rksat 2A/3A 42.0?E 11607 H 2960 5/6 feeds new 24.01.2010 East3ALast edited by Manic01; 10 May, 2010, 09:26. -
lm a sat noob now . why would u need this .. need to get up to speed on sat lads as lm having it installed nowany information provided is for educational/experimental purposes only.Comment
well im in the sat club now .. why did l wait so long ?any information provided is for educational/experimental purposes only.Comment
This would normally make sense after a couple of glasses of wineOriginally posted by otenet70vbvnnnnnmgggggggggggggggggg
but I suppose I have not had enough to drink.
cant find Sirius 4 (4.8E) l have put a new xml in enigma folder , rebooted and still cant see it ? is a dm600 .. any ideas where lm going wrong
l did this but cant see how u can write 4.8 e when u cant use a dot
To add a new satellite to your dreambox you need to add it in the satellite configuration after adding it in transponder edit first. On my dreambox i found if you didn't get it right first time the name doesn't appear in the list, just a blank space
Menu > 6> Service searching> Transponder edit. (this is the bit that has to done right first time, if you go back and edit it after it has been saved the rest won't work)
Click on Sat then press green button to add new satellite
go back to main menu after adding new satellite details
6> Service serching > Satellite configuration > Many Sats DISEqC rotor > yellow button.
It should add it to the bottom of the list in the sat config.
When you go to Motor setting it will then be added at the bottom of the list.Last edited by smirnoff_rules; 31 January, 2010, 15:22.any information provided is for educational/experimental purposes only.Comment
