satellite xml
  • philipgr
    • 72
    satellite xml
    looking for sat xml file for dream thxs
  • Manic01
    • 5117
    Satellite Pos. Freq. Pol. SR FEC Name update Date BEAM Provider DVB
    Eutelsat W2A 10.0?E 10714 V 3255 5/6 Channel 11 feeds new 24.01.2010 Europe
    Express AM 22 53.0?E 12736 H 2592 3/4 feeds new 24.01.2010 S2
    Intelsat 905 24.5?W 11066 V 3980 3/4 Testings new 24.01.2010 Spot1
    Intelsat 905 24.5?W 11603 V 17220 3/4 data service SR 24.01.2010 Spot1 S2-8PSK
    Turksat 1C 31.0?E 10994 V 2170 3/4 AKS TIMO feeds new 24.01.2010 west
    Turksat 1C 31.0?E 10999 V 2200 3/4 D?ğ?n TV Freq 24.01.2010 west1C D?ğ?n TV
    Turksat 1C 31.0?E 11002 V 2222 5/6 feeds FEC 24.01.2010 west1C
    T?rksat 2A/3A 42.0?E 10958 H 2222 5/6 feeds new 25.09.2009 East3A
    T?rksat 2A/3A 42.0?E 11156 H 4444 5/6 feeds new 24.01.2010 West3A
    T?rksat 2A/3A 42.0?E 11168 V 6666 5/6 feeds new 24.01.2010 West3A
    T?rksat 2A/3A 42.0?E 11465 H 14578 1/2 data service FEC/SR 24.01.2010 East3A SkyARCS S2-8PSK
    T?rksat 2A/3A 42.0?E 11607 H 2960 5/6 feeds new 24.01.2010 East3A
    • smirnoff_rules
      • 8603
      lm a sat noob now . why would u need this .. need to get up to speed on sat lads as lm having it installed now
      • red devil
        • Oct 2008
        • 690
        to scan a particular sat or sats
        or go here and create your own
        http://satellites-xml.eu/
        • Sattalk
          • 66
          Thanks may come in handy one day.
          Any information I provided is for educational/experimental purposeses only.
          • smirnoff_rules
            • 8603
            well im in the sat club now .. why did l wait so long ?
            • Curious123
              • 2591
              Sat equivalent of the cables.xml file.
              • Curious123
                • 2591
                Originally posted by otenet70
                vbvnnnnnmgggggggggggggggggg
                This would normally make sense after a couple of glasses of wine
                but I suppose I have not had enough to drink.
                • red devil
                  • Oct 2008
                  • 690
                  and hows it goin so far m8
                  • smirnoff_rules
                    • 8603
                    cant find Sirius 4 (4.8E) l have put a new xml in enigma folder , rebooted and still cant see it ? is a dm600 .. any ideas where lm going wrong
                    l did this but cant see how u can write 4.8 e when u cant use a dot
                    To add a new satellite to your dreambox you need to add it in the satellite configuration after adding it in transponder edit first. On my dreambox i found if you didn't get it right first time the name doesn't appear in the list, just a blank space
                    Menu > 6> Service searching> Transponder edit. (this is the bit that has to done right first time, if you go back and edit it after it has been saved the rest won't work)
                    Click on Sat then press green button to add new satellite
                    go back to main menu after adding new satellite details
                    6> Service serching > Satellite configuration > Many Sats DISEqC rotor > yellow button.
                    It should add it to the bottom of the list in the sat config.
                    When you go to Motor setting it will then be added at the bottom of the list.
                    • smirnoff_rules
                      • 8603
                      its ok l have do it ,,
