i have a question: with my DM500s, I can lock, scan these 3 satellites (hotbird, astra1 and astra2) and watch their channels without problem. only problem: arabsat 30.5: I can't get any lock and scan. Could it be that I have to update this file: satellites.xml?
It could be that the signal from 30.5 is weak or your dish could be misaligned so you are not getting good enough signal to lock on to the transponder.
ok, but if dish was misaligned, should I get 28.2 with 90% SNR and 0 BER?
