stream from your dreambox to a remote computer
  • mfaraj57
    • 557
    #16
    Hi
    The program designed to work with windiws xp and dreambox 500 .Although it works with vista and other enigma 1 based dreamboxes but give proplems
    The program code belong to visual basic 6 which is old language for modern systems add to this the difficult jop to connect two different systems micorsoft windows and dreambox linux.
    However i am working now to release new edition from the program coded by modern .net programming language which should be more stable with windows vista and even windows xp and as rule when dreambox freeze the program will freeze and so many proplems of the program will be solved by restarting the dreambox
    • besnik46
      • Mar 2009
      I am tryn to conect but nothing hapens i mean with dreambox viewer 4.0. i am trayng to conest remotly form mu work to my home dreambox
      any idea thenks
      • kgalal1981
        • Mar 2009
        i want to know how to watch dreambox on my pc
        • pug
          • 72
          #19
          Originally posted by alunfennell
          Hi dxc,
          use this software it will work far better, just add the IP address of your brother into it on startup, no need for vcl player, it uses WDP instead.
          Regards:
          Alun
          i,m using mfaraj viewer already working well, how do I log in from my dad,s house. ip address ? can u pm me how!
          • mfaraj57
            • 557
            #20
            Hi
            some points about dreambox viewer 4
            1- The program is designed to work within home lan and not to control or view remotely by internet
            the program depends upon windows media player and hope next release wmp12 will make restreaming is easier so restreaming over internet will be included in the program in the next version
            2- Program is designed for windows xp and has many proplems with vista although it works
            beta version from program is more stable and compatible with vista even doesnot need setup ,you can find it in this link and any suggestions are welcome to the email included in the program
            4shared.com - online file sharing and storage - download mfaraj dmviewer4.5vista beta 2.rar
            • jdz01
              • Mar 2009
              #21
              Hello, on my LAN I use VLC, version 0.8.6i. Neweer versions did not work. 0.8.6i works, but most of the time not at once. I have to swicht channels some time (by webx-tv connection), then the streaming video comes up. Is there a solution for this minor problem?
              JDZ
              • ces
                • Mar 2009
                • 104
                #22
                you can stream via ya browser...just type in the ip addy of the stb in in ya browser login then hit the vpid radio key then away ya go the picture appears on the screen...easyest way to do it
                ces
                • macao100
                  • Mar 2009
                  Thank s for all
                  An idee for stream divx from pc to dream ?
                  • alunfennell
                    • Oct 2008
                    • 1525
                    #24
                    What you need !
                    -a pc
                    -a dreambox or a linux based box
                    -ethernet cable
                    -video files...
                    and these softwares(attached in this post)
                    Note please,this will work on every box .
                    Now follow these steps on your pc:
                    -Install on your pc VLC Media Player 0.8.1
                    -after the installation go on your desktop and on the icon of the program go to property-destination and add this line after the words already wrote "--intf wxwin --extraintf=http" .
                    -start vcl from the same icon you have edited
                    -go to settings-preferences-input on Server port write 8080 and save this change
                    -open the file xml of vlc client 0.2.3
                    -on "server ip" write the ip of your pc on "config stardir" the path where are the files you want see on your box
                    -save these changes
                    ON your dreambox
                    -copy the files of vcl client 0.2.3 in this way(by a ftp software):
                    "vlc.xml" on "/var/tuxbox/config"
                    "vlc.cfg" and "vlc.so" on "/var/tuxbox/plugins"
                    -go on your dream and open the plugins area(often the yellow button)and open "VideoLanClient"...now you can see all the files of that folder.
                    Regards:
                    Alun
                    **The Worlds Best Interactive F1 Strategy Game**
                    • nikh
                      • Mar 2009
                      My boss as just asked me to find something like this - well better than doing real work. - thanks for the info
                      • elmoro
                        • Apr 2009
                        hmm
                        Unfortunatly this doesnt work out to well for me, i feel i'm banging my head into the wall...
                        Hope i can make some of the guides work out.
                        • opsmonkey
                          • 5379
                          #27
                          this is has been working well but recently i cant access anything on the left hand side, bouquets, providers, all services.. it comes up with errors saying not connected to dreambox but it is still streaming video..?? even when i press refresh it is ok until i click on providers or satellite, then the error message comes back..
                          i still continue to view stream, even in the settings when i use test connection it says ok..?
                          Any ideas..??
                          • alunfennell
                            • Oct 2008
                            • 1525
                            #28
                            opsmonkey I am having the same issue ...I found out that a lot of this program is built on other trial based software and the licensing has run out for some of it causing different issues... I have spent some time on this and it Fuc!ed my head for ages untill I found the underlined problem, noting we can do untill new version is released...
                            Regard:
                            Alun
                            • opsmonkey
                              • 5379
                              #29
                              cheers alun.. it was getting right on my tats.. i knew it was working fine last time i used it.. My mate is staying on the sofa and i thought great i can watch the...er.. er.. sport channels.. yes sport channels, via my laptop and the viewer.. obviously not.. the prog creator was here the other day saying he's working on a new Enigma 1 version
                              • colombo2530
                                • Jun 2009
                                wont let me download
                                A tutorial explaining how to stream from your dreambox to a remote computer.
                                courtesy of Rocknroll & Templo
                                wont let me download says i havnt got access
