when port forward as ip static will be this of pc or this of db?
stream from your dreambox to a remote computer
Hi Alun,
Dont seem to be able to open this file????????????
Can you help?
I would be grateful if you could provide some 'set up' notes if you have them. ( simple for a newbi)
Best Regards,
JohnComment
Alun,
Cant open the software????????Can you help?
It sounds brilliant and would like to try it out.
If you have some 'basic' set up instructions (for a newbi) that would be wonderful.
Best Regards,
JohnComment
I have a VU+ Duo, heres how i got mine going. created a free dyndns.com host name. Logged into my netgear router and under Dynamic DNS I specified my hostname that i created with the username and password. Then went into my VU+ and downloaded Password changer and enabled HTTP server so that i can access the box remotely. I then typed my host name into the browser and it prompted me for my username, root by default and the password, what i jsut created. This got me logged into my VU where i could stream then. I have a 17meg upstream. What i then did was downloaded XBMC player on my laptop and congifured it to be able to stream from my box so that I do not have to use the browser to stream. XBMC lets me see the boquets and select one to stream instead of downloading an m3u file and then streaming through vlc. I hope this makes sense, if you need to drop me a PM and ill certainly try to help! I'm only a beginner with all this but i was able to set it up my self by messing around with the config. P.S the port for the vu is port 80, i strongly recommend changing it to a different port for security reason.
Don't disrespect the Bing!Comment
Hello all,
I am new to this but as I have been setting up my box I have come across many helpful tips..Thx for them...but there are also many that are a tad misleading (or maybe I just didn't get the whole story). As a result I would like to add some more info from my present experience. I now have my Dreambox 800 streaming to my pc using TS Dreambox Streamer. When I ran the program at first I had no video or audio. After a lot of research I found a link that stated you need VLC player version 1.0.5 or less and now...hey presto it works!Comment
