Dependent on model and image there should be a setting in network setup to allow you to add/edit DNS settings. Just assign the same gateway address, (your router address), to DNS1 or use the link I gave you to pick one or two servers.
Def use the ip of your router... from someone who learnt the hard way!!
99% of the time thats correct recently on a Netgear i had to use Virgins Nameserver for it to work.
The Netgear ip wouldnt work so used 194.168.4.100 which is Virgins Primary Nameserver.
Broken router firmware, an all too common problem these days even though it should be easy for the router manufacturers to get it right.
Generally, the router should be able to grab the provider specified nameservers and then forward all requests it cant fullfil (which will be nearly all) onwards.
