nameserver setting
  • kbliverpool
    • 57
    nameserver setting
    what is the nameserver setting on the drembox to connect to the internet i have all the others ticked not that one thanks
    it is sat dreambox
    it is a netgear router
  • satsmo
    • 6397
    Moved to sat section.
    You can use the default address, (unless you have changed it, if so use that address), of your router as a DNS.
    Alternately you can choose a DNS server here http://www.dnsserverlist.org/
    • kbliverpool
      • 57
      i was using a three dongle before but now i am using netgear with ntl got three ticks but not the name server
      • satsmo
        • 6397
        Dependent on model and image there should be a setting in network setup to allow you to add/edit DNS settings. Just assign the same gateway address, (your router address), to DNS1 or use the link I gave you to pick one or two servers.
        • kbliverpool
          • 57
          i have got the 4 ticks now but no tv i am using blackhole image
          • nxh
            • Dec 2011
            I put to nameserver the same ip as the router, but stil have unconfirmed message for nameserver at network test , all others are OK
            • tomhick024
              • 559
              Def use the ip of your router... from someone who learnt the hard way!!
              Whatever!!
              • andy91
                • Aug 2010
                • 3583
                99% of the time thats correct recently on a Netgear i had to use Virgins Nameserver for it to work.
                The Netgear ip wouldnt work so used 194.168.4.100 which is Virgins Primary Nameserver.
                Andy
                • SatSearching
                  • 447
                  On your main pc, run cmd and do ipconfig /all, note your dns and use on your dreambox.
                  Failing that, just set a safe public dns on your dreambox such as google i.e. set it to 8.8.8.8
                  SS
                  • TheCoder
                    • Jun 2011
                    • 693
                    Broken router firmware, an all too common problem these days even though it should be easy for the router manufacturers to get it right.
                    Generally, the router should be able to grab the provider specified nameservers and then forward all requests it cant fullfil (which will be nearly all) onwards.
