SGTFlipFlop SKYUK Bouquets - Updated Regularly
You can generate your own xml file from http://satellites-xml.eu then ftp it over to your satellite box. -
no your not understanding me , some of the channels (hd channels ) wont open even after you update the satellite.xml file . they will be there on your epg but they wont open , that's not because of a frequency change but due to changes that sky have implemented , theres nothing atleast right now that will fix those specific channels . but an updated satellite.xml file will ensure that you will be able to receive all other channels that currently still open . you can download an up todate satellite.xml file from the following link .
satellites.xml generator / transponder .ini generator
if your current satellite.xml file is reasonably up to date a scan will usually suffice to bring back channels that have changed frequency etc , but as I say a scan wont make those specific channels open .Leave a comment:
Where do I get an updated satellite.xml file from if there isn't a new one for this set of channels, please?some of the hd channels are not opening due to changes implemented by sky , theres nothing you can do about those channels as we speak or maybe there never will be . but you should update your satellite.xml file on a regular basis and also do a scan atleast maybe every few weeks just to stay up to date .
And for rescanning, does that sometimes work without having made any other changes?Leave a comment:
some of the hd channels are not opening due to changes implemented by sky , theres nothing you can do about those channels as we speak or maybe there never will be . but you should update your satellite.xml file on a regular basis and also do a scan atleast maybe every few weeks just to stay up to date .Leave a comment:
I've still got 5USA, but recently a number of channels no longer work, such as Sky Living (SD), Sky 1 HD, Sky Living HD, Sky Atlantic HD, and some of the HD movies inc. Premiere, Disney, SciFi/Horror
Is there a new list due which will fix this, please?Leave a comment:
5 usa hasn't changed frequency , I mean its atleast working on my box . but I add an up to date satellite.xml file every so often , my last up date was a few months back and nothing has changed for 5 usa so I can only think you .xm file is badly out of date . add n up to date satellite .xml file to your e1 or e2 box , if you don't know how just say and ill help you , then do a reboot and a scan for channels . of course if your missing certain hd channels from sky this wont fix that problem .Leave a comment:
Any one got new channels as im missing a good few like 5 USA and more
Sent from my GT-I9195 using TapatalkLeave a comment:
Can someone help re: Radio channels, please?Leave a comment:
This thread is for the Sarge's UK bouquet channel ;ist what you require is a Multi satellite list so you have a choice you can either install Catseye list from here: http://www.digital-kaos.co.uk/forums...ml#post2284494
Or you could use the Vhannibal Autobouquet maker from here: http://www.digital-kaos.co.uk/forums...plugin-413614/ this will update your Multi sat list direct from the Plugin menuLeave a comment:
hi there
some channels have been movied about, anyone out there got the latest bouquets for:
4.8E
9.0E
13.0E
16.0E
19.2E
23.5E
28.2E
0.8W
5.0W
Kind regards
SheernessLeave a comment:
boxnation has moved dooby
BoxNation
United Kingdom Sport Sky Digital VideoGuard 55305 2384 2385 eng 279 2384 2014-04-22 Leave a comment:
Hi All,
Can comeone please check if boxnation is working for them? Mine comes up with tune failed. Updated the latest bouquet available on my dm800
thanksLeave a comment:
Hi Flipflop, I am a new be to VU DUO 2 how do I load this file to the VU BOX thanks for your hellpLeave a comment:
Eutelsat 28A
Leave a comment:
