SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • andy91
    replied
    Try another set even if they are old ones. Most channels should work.
    Andy.
    Leave a comment:
  • mtv1
    replied
    have a look in var/etc/cccam.cfg see if the magic is there ...i've never seen adding a channel list remove the magic before and i'm an old dog
    Leave a comment:
  • alantreet
    replied
    Thanks for the latest bouquet but I have a couple of problems.
    I've just gone through the procedure with this and DBE to put the files on my Dreambox (800HDSE) but while the log tells me it has transferred the files across, none of the userbouquet.dbe**.tv files are showing in my /etc/enigma2 folder on the Dreambox.
    Also, while I rescanned for channels and found them all, including the renamed ones (eg. MTV Xmas), none of the scrambled channels will appear onscreen. I've tried restarting my CCcam 2.3.0 but to no avail. They were working before I started this procedure.
    Hence, I'm not sure if everything has transferred across like it should since the files appear to be missing yet the Dreambox knows what the new ones are called. I've only had the Dreambox a few months and I don't tinker with it much so I still consider myself a newbie with this sort of thing.
    Also, and it's a minor point but it was there in the last bouquet I used (the Dec 2012 batch), all the channel names also had the Sky channel number at the start. I've added some manually, but can this be considered again in future, please? It just makes it easier when setting up programmes.
    I can see for some it might look a bit odd when, for example, it says "645 101 BBC1 N West", however, I wish it didn't have '645' at the start and I could select the channel with 101, but I'm not sure if I can do anything about that.
    Leave a comment:
  • SGTFlipFlop
    replied
    They work without being set to 8PSK
    Leave a comment:
  • SGTFlipFlop
    replied
    Star Plus HD?
    Leave a comment:
  • hkambo
    replied
    Originally posted by hkambo
    is star HD working for everyone ??
    worked out my own answer ...changed the modulation to 8PSK and all working now inc WATCH HD which was also affected
    Leave a comment:
  • hkambo
    replied
    Leave a comment:
  • SGTFlipFlop
    replied
    Here is the latest update
    DreamboxEdit 5.3.0.0 Used (Recommended) Guide Here
    Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
    Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800 and many more....
    Updates: 27th November 2013
    BBC Four HD (New Channel)
    BBC News HD (New Channel)
    BBC Three HD (New Channel)
    CBBC HD (New Channel)
    The Style Network Renamed to E! +1
    Nick Jr. Renamed to Nick Jr Xmas
    Nick Jr. Peppa Renamed to Nick Jr. 2
    S4C (New Frequency)
    Showcase 2 +1 (New Frequency)
    Sky Movies Drama & Romance Renamed to Sky Christmas
    Sky Movies Drama & Romance HD Renamed to Sky Christmas HD
    Removed Channels
    The Style Network
    Picons
    Updated newest channels
    Before these Numbering bouquets work you need to make some changes to DBE and your Enigma2 box
    For Regional changes you will now need to do these in SGTFlipFlop & Entertainment bouquets now.
    in DBE options > advanced > make sure all boxes are ticked especially Allow Duplicate Entries
    On Dreambox make sure Multi Bouquets are ticked (Menu>Setup>System>Customize>Expert>Enable Multi Bouquets-YES)
    The text in bold needs to be done before you open the bouquets in DBE, Thanks
    ** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
    These bouquets are positioned nearly identical to the Sky Box, Enjoy a neat up to date bouquet.
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK,
    All correctly mapped and a few obscure ones missing only
    Use any FTP client, DCC for example, to transfer the picon directory to
    one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    Always remove old picons from Dreambox before uploading new ones,
    Sometimes they don't overwrite correctly
    Please keep this thread clean, Use the Thanks button rather than posting on the thread
    Leave a comment:
  • SGTFlipFlop
    replied
    Channel 5 HD (New Frequency)
    More4 HD (New Frequency)
    MTV Classic Renamed to MTV Xmas
    Removed Channels
    Channel 5 HD
    More4 HD
    Picons
    /usr/share/enigma2
    /media/hdd
    /media/cf
    /media/usb
    Leave a comment:
  • SGTFlipFlop
    replied
    Got rid of Enigma1 files ages ago
    Sent from my HTC One using Tapatalk 2
    Leave a comment:
  • $Furious
    replied
    Hi where is the enigma1 files? cant seem to locate them only enigma2 showing in your attachments.
    Leave a comment:
  • SGTFlipFlop
    replied
    Updates: 22nd November 2013
    Bouquet Updates
    Massive update, again too many too list, fully updated channel list and Picons
    Updates
    Too many to mention just enjoy, Any errors let me know
    Removed Channels
    Too many to mention
    Picons
    /usr/share/enigma2
    /media/hdd
    /media/cf
    /media/usb
    Leave a comment:
  • SGTFlipFlop
    replied
    New update will be out tomorrow, Loads of changes from last update, Lots of work
    Leave a comment:
  • nas4u
    replied
    hi need help to locate latest file boquets e1 thanks cant find thanks
    Leave a comment:
  • piopat
    replied
    im not sure what you mean split but you can change an enigma 2 bouquet to enigma USING DREAMBOX IT , click on tools and there are options and one option is toggle between , click on that and it will change your bouquet from 2 to 4 and 4 to 2 , that's between e1 and e2 .otherwise you need an e1 bouquet which I don't think sgt is doing any more or you can use dreambox edit to create your own bouquets , its not that hard to make a basic bouquet (I mean with no sky numbers etc) so that's some thing you may consider .
    Leave a comment:
